跳转到主内容
Microsoft Surface Laptop 3 13.5" Feet Replacement
你所需要的
  1. Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: 步骤 1 中的图像 1,2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: 步骤 1 中的图像 2,2
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: 步骤 2 中的图像 1,2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: 步骤 2 中的图像 2,2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: 步骤 3 中的图像 1,3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: 步骤 3 中的图像 2,3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: 步骤 3 中的图像 3,3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: 步骤 4 中的图像 1,3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: 步骤 4 中的图像 2,3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: 步骤 4 中的图像 3,3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 步骤 5 中的图像 1,2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 步骤 5 中的图像 2,2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 步骤 6 中的图像 1,3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 步骤 6 中的图像 2,3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 步骤 6 中的图像 3,3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
结论
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
另外一个人完成了本指南。
Carsten Frauenheim
于03/10/20注册
135,533 声望
创作了371篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,413篇指南
一条评论
Nice, that good for me, first time :D
TrungLun0112 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 33
过去 30 天: 122
总计 7,573
