跳转到主内容
Microsoft Surface Headphones Motherboard Replacement
你所需要的
  1. Microsoft Surface Headphones Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Microsoft Surface Headphones Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Firmly grasp the ear cushions and rotate them counterclockwise, about 45 degrees, until you hear a "click."
    • To replace the motherboard, you only need to remove the right cushion, labeled with an "R" on the headband.
  2. Microsoft Surface Headphones Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the three 2.6 mm screws securing the right speaker housing to the chassis.
  3. Microsoft Surface Headphones Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift the speaker housing away from the chassis, taking care not to damage the motherboard connections.
    • Desolder the two speaker motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
  4. Microsoft Surface Headphones Motherboard Replacement: 步骤 4 中的图像 1,1
    • Desolder the red and black speaker connections.
  5. Microsoft Surface Headphones Motherboard Replacement: 步骤 5 中的图像 1,1
    • Desolder the 23 connections from the motherboard.
    • Before soldering the connections to your new motherboard, be sure to pay close attention to which wire goes where; they're very easy to mix up.
  6. Microsoft Surface Headphones Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a Torx screwdriver to remove the four screws.
    • Lift the motherboard up and out of the chassis.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 1,043
