跳转到主内容
Metal Snap Installation Using a Hand Press
你所需要的
  1. Metal Snap Installation Using a Hand Press, Metal snap types: 步骤 1 中的图像 1,2 Metal Snap Installation Using a Hand Press, Metal snap types: 步骤 1 中的图像 2,2
    • There are two main styles of metal snaps on Patagonia gear:
    • Flat Spring Snap - This style is commonly found on clothing because it snaps and unsnaps smoothly.
    • Durable Socket Snap - This style is commonly found on packs and luggage because it has thicker metal that can withstand heavy use.
    • Each piece of the snap has its own corresponding snap die. Make sure you use the correct size and style of snap.
  2. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: 步骤 2 中的图像 1,2 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: 步骤 2 中的图像 2,2
    • This tutorial will demonstrate with the Durable Socket Snap, but the same actions can be applied to the Flat Spring Snap.
    • Gather the stud and post pieces and their corresponding dies.
    • The stud and post are compressed together with the press to create the base of the snap.
  3. Metal Snap Installation Using a Hand Press, Insert the post into the post die: 步骤 3 中的图像 1,3 Metal Snap Installation Using a Hand Press, Insert the post into the post die: 步骤 3 中的图像 2,3 Metal Snap Installation Using a Hand Press, Insert the post into the post die: 步骤 3 中的图像 3,3
    • Insert the post piece into the post die so the flat part of the post sits inside the die with the shaft pointed out.
  4. Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: 步骤 4 中的图像 1,2 Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: 步骤 4 中的图像 2,2
    • Insert the post die into the lower fitting of the hand press.
  5. Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: 步骤 5 中的图像 1,3 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: 步骤 5 中的图像 2,3 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: 步骤 5 中的图像 3,3
    • Insert the stud piece into the stud die until it snaps into place.
  6. Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: 步骤 6 中的图像 1,3 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: 步骤 6 中的图像 2,3 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: 步骤 6 中的图像 3,3
    • Using your fingers, a screwdriver, or a hex key, as needed, unscrew the tightening mechanism on the side of the press near the die fitting.
    • Insert the die upward and hold it in place.
    • Tighten the tightening mechanism.
  7. Metal Snap Installation Using a Hand Press, Install the snap base: 步骤 7 中的图像 1,3 Metal Snap Installation Using a Hand Press, Install the snap base: 步骤 7 中的图像 2,3 Metal Snap Installation Using a Hand Press, Install the snap base: 步骤 7 中的图像 3,3
    • Lay the item to be repaired into the hand press so that the hole from the original snap rests directly above the shaft of the post.
    • If the fabric around the old snap is torn or damaged beyond a small hole, apply a patch to reinforce the area before replacing the snap.
    • Make sure no extra fabric is caught inside the press and that the orientation of the item is correct.
    • Hold the fabric in place with one hand, then use your other hand to pull down the handle of the press.
    • This requires a lot of pressure to make sure the snap replacement is successful - so pull hard!
  8. Metal Snap Installation Using a Hand Press, Quality control: 步骤 8 中的图像 1,2 Metal Snap Installation Using a Hand Press, Quality control: 步骤 8 中的图像 2,2
    • Release the handle of the hand press and remove the fabric.
    • Inspect both sides of the snap to make sure:
    • It's laying flat and tight up against the fabric.
    • It doesn't spin in place.
    • It fastens together securely with the head of the snap.
    • If the snap isn't set all the way, reinsert the snap into the hand press, aligning it as it was before, and pull the handle again.
  9. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: 步骤 9 中的图像 1,2 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: 步骤 9 中的图像 2,2
    • Gather the socket and cap pieces and their corresponding dies.
    • The socket and cap are compressed together with the press to create the head of the snap.
  10. Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: 步骤 10 中的图像 1,3 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: 步骤 10 中的图像 2,3 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: 步骤 10 中的图像 3,3
    • Insert the cap piece into the cap die so it sits inside the die with the shaft facing out.
  11. Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: 步骤 11 中的图像 1,3 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: 步骤 11 中的图像 2,3 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: 步骤 11 中的图像 3,3
    • Insert the cap die into the lower fitting of the hand press.
  12. Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: 步骤 12 中的图像 1,2 Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: 步骤 12 中的图像 2,2
    • Insert the socket piece into the socket die until it snaps into place.
  13. Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: 步骤 13 中的图像 1,3 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: 步骤 13 中的图像 2,3 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: 步骤 13 中的图像 3,3
  14. Metal Snap Installation Using a Hand Press, Install the snap head: 步骤 14 中的图像 1,3 Metal Snap Installation Using a Hand Press, Install the snap head: 步骤 14 中的图像 2,3 Metal Snap Installation Using a Hand Press, Install the snap head: 步骤 14 中的图像 3,3
  15. Metal Snap Installation Using a Hand Press, Quality control: 步骤 15 中的图像 1,2 Metal Snap Installation Using a Hand Press, Quality control: 步骤 15 中的图像 2,2
    • It fastens together securely with the base of the snap.
  16. Metal Snap Installation Using a Hand Press, Examples: 步骤 16 中的图像 1,2 Metal Snap Installation Using a Hand Press, Examples: 步骤 16 中的图像 2,2
    • The rain jacket in the first photo has flat spring metal snaps along the center front zipper placket.
    • The duffel bag in the second photo has durable socket metal snaps at the handle grip.
终点
3等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,475 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,746篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 92
过去 30 天: 308
总计 23,042
