跳转到主内容
MerchSource the Black Series Boat Racer Battery Cable Replacement
你所需要的
  1. MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: 步骤 1 中的图像 1,2 MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: 步骤 1 中的图像 2,2
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Cable Replacement: 步骤 2 中的图像 1,1
    • Slide the battery cover off.
  3. MerchSource the Black Series Boat Racer Battery Cable Replacement: 步骤 3 中的图像 1,2 MerchSource the Black Series Boat Racer Battery Cable Replacement: 步骤 3 中的图像 2,2
    • Remove both AA-batteries.
  4. MerchSource the Black Series Boat Racer Battery Cable Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Cable Replacement: 步骤 5 中的图像 1,3 MerchSource the Black Series Boat Racer Battery Cable Replacement: 步骤 5 中的图像 2,3 MerchSource the Black Series Boat Racer Battery Cable Replacement: 步骤 5 中的图像 3,3
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Cable Replacement: 步骤 6 中的图像 1,1
    • Solder the wire to reconnect it.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 207
