跳转到主内容
Merch Source Projector Entertainment II Cooling Fan Replacement
你所需要的
  1. Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: 步骤 1 中的图像 1,2 Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Cooling Fan Replacement: 步骤 3 中的图像 1,2 Merch Source Projector Entertainment II Cooling Fan Replacement: 步骤 3 中的图像 2,2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: 步骤 4 中的图像 1,2 Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: 步骤 4 中的图像 2,2
    • Locate the 80 mm fan and slide upward straight out of the housing.
  5. Merch Source Projector Entertainment II Cooling Fan Replacement: 步骤 5 中的图像 1,2 Merch Source Projector Entertainment II Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Unsolder the red and black connections off of the motherboard.
    • If there are zip ties around the cables, they will need to be cut to remove the fan.
    • Need some help? Follow this guide to learn soldering basics.
    • While soldering the metal connections will get very hot. Never touch the iron with your hand.
    • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
    • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
结论
另外一个人完成了本指南。
Stephanie
于01/08/15注册
282 声望
创作了3篇指南
团队
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G3
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 2,577
