跳转到主内容
Memorex Mi3X Minimove Speakers Replacement
你所需要的
  1. Memorex Mi3X Minimove Speakers Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • It may be helpful to pull the plastic covers out with your fingers once the top of the cover has been revealed by using the plastic opening tool.
  2. Memorex Mi3X Minimove Speakers Replacement: 步骤 2 中的图像 1,1
    • This step will require at least a 30 mm Phillips #1 screwdriver.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws.
  3. Memorex Mi3X Minimove Speakers Replacement: 步骤 3 中的图像 1,1
    • The bottom panel screws and screw covers must be removed in order to access the back panel.
    • Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
    • The adhesive on the screw covers should be sticky enough to put the covers back on when re-assembling the device.
  4. Memorex Mi3X Minimove Speakers Replacement: 步骤 4 中的图像 1,1
    • Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 12 mm screws with a long Phillips #1 screwdriver.
  5. Memorex Mi3X Minimove Speakers Replacement: 步骤 5 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement: 步骤 5 中的图像 2,2
    • To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
  6. Memorex Mi3X Minimove Speakers Replacement: 步骤 6 中的图像 1,3 Memorex Mi3X Minimove Speakers Replacement: 步骤 6 中的图像 2,3 Memorex Mi3X Minimove Speakers Replacement: 步骤 6 中的图像 3,3
    • Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed.
    • After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
    • Carefully pull the panel off.
  7. Memorex Mi3X Minimove Speakers Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
  8. Memorex Mi3X Minimove Speakers Replacement: 步骤 8 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement: 步骤 8 中的图像 2,2
    • If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
  9. Memorex Mi3X Minimove Speakers Replacement: 步骤 9 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Remove the five 6 mm screws at the top with the same screwdriver.
  10. Memorex Mi3X Minimove Speakers Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
  11. Memorex Mi3X Minimove Speakers Replacement: 步骤 11 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement: 步骤 11 中的图像 2,2
    • Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
    • Use moderate force to pry it open and take the cover off.
  12. Memorex Mi3X Minimove Speakers Replacement, Radio: 步骤 12 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement, Radio: 步骤 12 中的图像 2,2
    • A plastic sheet is in between the radio motherboard (the upper brown board) and the audio port daughterboard (the lower green board) coming from the right speaker housing. Be careful when removing the back panel as to not damage the boards.
    • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
  13. Memorex Mi3X Minimove Speakers Replacement: 步骤 13 中的图像 1,3 Memorex Mi3X Minimove Speakers Replacement: 步骤 13 中的图像 2,3 Memorex Mi3X Minimove Speakers Replacement: 步骤 13 中的图像 3,3
    • Pull out the 5 white pinhead connectors using an IC (Integrated Circuit) extractor. Pinch the IC extractor just under the top lip of the wire housing. There are two 10 pin connectors, one 8 pin connector, one 7 pin connector, and one 2 pin connector.
    • When reassembling, there is only one way to reinsert the pinhead connectors. Make sure the orientation matches that of the receiving connector on the motherboard.
  14. Memorex Mi3X Minimove Speakers Replacement: 步骤 14 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement: 步骤 14 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the three 8 mm screws holding the motherboard in place.
  15. Memorex Mi3X Minimove Speakers Replacement: 步骤 15 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement: 步骤 15 中的图像 2,2
    • Detach the smaller green audio port daughterboard by removing the two 8 mm screws with a Phillips #1 screwdriver.
  16. Memorex Mi3X Minimove Speakers Replacement: 步骤 16 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement: 步骤 16 中的图像 2,2
    • Detach the black ground wire by desoldering it from the inner case.
    • Visit the soldering guide for help with desoldering.
  17. Memorex Mi3X Minimove Speakers Replacement, Speakers: 步骤 17 中的图像 1,3 Memorex Mi3X Minimove Speakers Replacement, Speakers: 步骤 17 中的图像 2,3 Memorex Mi3X Minimove Speakers Replacement, Speakers: 步骤 17 中的图像 3,3
    • Use a Phillips #1 screwdriver to unscrew the two 8 mm screws on the speaker housing.
  18. Memorex Mi3X Minimove Speakers Replacement: 步骤 18 中的图像 1,3 Memorex Mi3X Minimove Speakers Replacement: 步骤 18 中的图像 2,3 Memorex Mi3X Minimove Speakers Replacement: 步骤 18 中的图像 3,3
    • The speaker housing may require more force than expected to remove because it is held together by a thin black rubber adhesive. Do not be afraid of using more force if you are unable to remove it on the first try.
    • When the housing is removed the rubber adhesive will come off. This should not effect your device's functionality in any way.
    • Grab the outside of one speaker housing and pull outwards (starting with the top) while holding the main casing still with your other hand.
  19. Memorex Mi3X Minimove Speakers Replacement: 步骤 19 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement: 步骤 19 中的图像 2,2
    • Unscrew the three 8 mm circled screws that are holding the speaker to the plastic casing.
  20. Memorex Mi3X Minimove Speakers Replacement: 步骤 20 中的图像 1,1
    • The speaker is still attached to the speaker board in the boombox. Do not attempt to move the speaker too far away from the boombox.
    • Remove the speaker from the housing and place it next to the boombox.
  21. Memorex Mi3X Minimove Speakers Replacement: 步骤 21 中的图像 1,2 Memorex Mi3X Minimove Speakers Replacement: 步骤 21 中的图像 2,2
    • The upper wire connector, marked in red, connects the left speaker to the boombox. The lower wire connector, marked in orange, connects the right speaker to boombox.
    • Do not remove the wire connector from the speaker daughter board by pulling on the wire. This may damage the wire and the board.
    • Use your hands to grip the plastic wire housing and detach the upper speaker wire connector from the speaker daughterboard.
结论
4等其他人完成本指南。
Alec Cheung
于01/29/14注册
270 声望
撰写一个指南
团队
Cal Poly, Team 2-9, Amido Winter 2014 Cal Poly, Team 2-9, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G9
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 1,301
