跳转到主内容
Master and Dynamic MW50 Charging Port Replacement
你所需要的
  1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 1,3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 2,3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 3,3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Charging Port Replacement: 步骤 3 中的图像 1,1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Charging Port Replacement, Charging Port: 步骤 4 中的图像 1,2 Master and Dynamic MW50 Charging Port Replacement, Charging Port: 步骤 4 中的图像 2,2
    • Remove the two 2mm screws pictured with a JIS #00 screwdriver.
    • Gently pull the silver cover off of the ear piece.
  5. Master and Dynamic MW50 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Remove the two 2mm screws shown with a JIS #00 screwdriver.
  6. Master and Dynamic MW50 Charging Port Replacement: 步骤 6 中的图像 1,1
    • Lift up the mother board with the attached charging port to see the soldering points. You must desolder these points in order to detach (and re-attach) the charging port.
结论
Tyler Guffey
于01/24/19注册
208 声望
创作了2篇指南
团队
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 的会员
CPSU-WHITE-W19S1G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 310
