跳转到主内容
Master and Dynamic MW50 Battery Replacement
你所需要的
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 1,3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 2,3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 3,3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: 步骤 3 中的图像 1,1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: 步骤 4 中的图像 1,2 Master and Dynamic MW50 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: 步骤 5 中的图像 1,1
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: 步骤 6 中的图像 1,2 Master and Dynamic MW50 Battery Replacement: 步骤 6 中的图像 2,2
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
结论
Tyler Guffey
于01/24/19注册
208 声望
创作了2篇指南
团队
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 的会员
CPSU-WHITE-W19S1G4
4 名成员
创作了12篇指南
一条评论
Hi, do you know where it’s possible to buy replacement batteries??
Mike - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 44
总计 1,777
