跳转到主内容
Martian Victory Motherboard Replacement
你所需要的
  1. Martian Victory Motherboard  Replacement, Back Plate: 步骤 1 中的图像 1,2 Martian Victory Motherboard  Replacement, Back Plate: 步骤 1 中的图像 2,2
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory Motherboard  Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Motherboard  Replacement, Lithium Battery: 步骤 3 中的图像 1,1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Motherboard  Replacement: 步骤 4 中的图像 1,1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory Motherboard  Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Martian Victory Motherboard  Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Martian Victory Motherboard  Replacement: 步骤 7 中的图像 1,1
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Martian Victory Motherboard  Replacement: 步骤 8 中的图像 1,3 Martian Victory Motherboard  Replacement: 步骤 8 中的图像 2,3 Martian Victory Motherboard  Replacement: 步骤 8 中的图像 3,3
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Martian Victory Motherboard  Replacement: 步骤 9 中的图像 1,2 Martian Victory Motherboard  Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
结论
Dominic Coffey
于10/24/16注册
243 声望
创作了2篇指南
团队
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S3G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 190
