跳转到主内容
加入维修社区 - 创建账户
Martian Victory LED Screen Replacement
你所需要的
  1. Martian Victory LED Screen Replacement, Back Plate: 步骤 1 中的图像 1,2 Martian Victory LED Screen Replacement, Back Plate: 步骤 1 中的图像 2,2
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory LED Screen Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory LED Screen Replacement, Lithium Battery: 步骤 3 中的图像 1,1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory LED Screen Replacement: 步骤 4 中的图像 1,1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory LED Screen Replacement, LED Screen: 步骤 5 中的图像 1,1
    • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
  6. Martian Victory LED Screen Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • With a pair of tweezers, carefully remove the ribbon strip connection.
  7. Martian Victory LED Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the screw driver holding the LED screen and Speaker in place.
  8. Martian Victory LED Screen Replacement: 步骤 8 中的图像 1,1
    • Insert a small flat screw driver under the speaker in order to remove it.
  9. Martian Victory LED Screen Replacement: 步骤 9 中的图像 1,2 Martian Victory LED Screen Replacement: 步骤 9 中的图像 2,2
    • Using tweezers, remove the speaker and move off to the side.
  10. Martian Victory LED Screen Replacement: 步骤 10 中的图像 1,2 Martian Victory LED Screen Replacement: 步骤 10 中的图像 2,2
    • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
  11. Martian Victory LED Screen Replacement: 步骤 11 中的图像 1,1
    • Remove final connection to accelerometer. The LED screen is now separated from the device.
结论
Robert Sanchez
于10/31/16注册
201 声望
创作了2篇指南
团队
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S3G3
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 305
