你所需要的
Remove the volume, tone and power knobs by pulling them straight away from the front of the device. If they do not come off easily use the wedge tool to pry them up.
Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
First do a visual check. Looked for cracked solder or damaged components.
The image on this page shows a wire who's solder has completely detached from the board.
To fixed cracked or detached solder, use the soldering iron to heat the solder already there until it flows and becomes completely attached to the board.
To replace damaged components use the iron to remove and replace them.
Use a multimeter to test the potential difference across the components. You will have to reinstall the batter and turn the device on to do this.
Put one of the pins on each side of the component. Read the value on the meter.
Each resistor has a predefined value that can be found using this page. Compare the results to the expected values.
The capacitors have there properly functioning values printed on them.
If any values vary replace the component.
另外一个人完成了本指南。
一条评论
HOla, hace años tengo uno y por cosas de la vida, un amigo que quiero matar, jejeje... le puso un adaptador de corriente de 12V, y sabemos que funciona con 9... asi que me gustaria saber que pudo haberse dañado para poder repararlo... por cierto, el led funciona normal al conectar.. pero no emite sonido alguno.. saludos
