简介
These instructions will show you how to replace the rear axle of your Makita DLM431 lawn mower.
你所需要的
Remove lock key and the grass-catching basket.
Put the lawnmower on its head and store it safely.
Loosen the nut of the wheels with a 13mm spanner.
Pull the wheel off the axle
Loosen the nut of the connection between rear axle and axle adjustment with the 13mm nut.
Pull off the axle adjustment linkage.
Remove screws with a Phillips screwdriver.
Push the axle holder backwards through the fairing to expose the axle.
Congrats! Now follow the steps in reverse order to reassemble your unit.
3等其他人完成本指南。
由衷感谢以下译者:
100%
carlotremolada正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
