跳转到主内容
Making a low cost photography light stand
你所需要的
  1. Making a low cost photography light stand, Unplug the lamp: 步骤 1 中的图像 1,1
    • Before disassembling on the lamp, it MUST be unplugged!
  2. Making a low cost photography light stand, Remove the lightbulb: 步骤 2 中的图像 1,3 Making a low cost photography light stand, Remove the lightbulb: 步骤 2 中的图像 2,3 Making a low cost photography light stand, Remove the lightbulb: 步骤 2 中的图像 3,3
    • If the bulb is worth keeping, this can be reused.
    • If the lamp has a lightbulb installed, remove it from the lamp.
  3. Making a low cost photography light stand, Remove the socket cover: 步骤 3 中的图像 1,3 Making a low cost photography light stand, Remove the socket cover: 步骤 3 中的图像 2,3 Making a low cost photography light stand, Remove the socket cover: 步骤 3 中的图像 3,3
    • MOST LAMPS WILL BE SIMILAR, but designs can vary.
    • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
    • Remove the socket cover. Once removed, remove the bulb socket.
  4. Making a low cost photography light stand, Remove the bulb socket: 步骤 4 中的图像 1,2 Making a low cost photography light stand, Remove the bulb socket: 步骤 4 中的图像 2,2
    • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
    • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
    • Discard any broken or unwanted components.
  5. Making a low cost photography light stand, Remove the cord: 步骤 5 中的图像 1,3 Making a low cost photography light stand, Remove the cord: 步骤 5 中的图像 2,3 Making a low cost photography light stand, Remove the cord: 步骤 5 中的图像 3,3
    • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
    • After removing the bulb socket, remove the power cord.
  6. Making a low cost photography light stand, Test the lamp and find a good clamp point: 步骤 6 中的图像 1,1
    • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
终点
Nick
于11/10/09注册
88,851 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 447
