本指南有最近更改,您可查看未经巡查的最新版本。
简介
The magic of the Magic Trackpad is its ability to physically click - while appearing to not have any moving parts.
The secret to the Magic Trackpad's clicking ability is in those innocuous looking round rubber feet on the bottom. They're not just there to be normal old rubber feet that merely provide grip to keep it from sliding around on your desk. And they're not entirely rubber, either. The rubber you see and feel protruding from the bottom is only a very thin and fragile sheath covering a hard plastic foot.
The feet need to be rigid: When you click the surface by pressing down on it these rubber/plastic feet are the only parts of the trackpad that *don't move*.
This guide will explain how to re-insert one (or both) of the Magic Trackpad's rubber feet
你所需要的
Unscrew the battery door by turning the screw counter-clockwise with a flat edge screwdriver, coin, plastic opening tool, or fingernail.
The rubber buffer consists of two parts, a rigid part made of plastic and the sheath is made of rubber.
If the shape of the foot is not perfectly spherical, as in the photo, which can be caused by one of the two rubber flap that came out of the notch. Put it back. And it is spherical again.
Using a small flathead screwdriver, gently break the seal between the white plastic backing and the metal top.
Pry up the corner with the screwdriver
Place the rubber foot back in place.
Squeeze closed the backing and metal (it will snap into place).
Click on trackpad to test.
Insert the battery and you are done.
It may happen again when you move inadvertently a sheet of paper under the trackpad contributing involuntarily to the extraction of one of the rubber feet.
If you want to remove the plastic cover completely I recommend opening it from the top side not to break any of the clips in the bottom. The cover is attached to the trackpad through rubber glue on the plastic grid and four clips in the bottom.
It is a convenient and even a better method in order to not alter the fragile rubber feet. Take your time to slowly open the plastic cover from the top side.
175等其他人完成本指南。
65条评论
where can i buy the plastic feet?????
Yes. Where can I buy the rubber feet?
I bought mine off Ali Express. There’s quite a few stores on there that sell them. Here’s the one I bought from.
Found this guide confusing. Here's what worked for me:
1. Place the tip of a butter knife inside the hole and gently lift the plastic high enough to place the tip of another butter knife on the side and hold the plastic up.
2. Remove the first butter knife from the hole. Gently raise the plastic with the second butter knife high enough to slide the foot underneath.
3. Use the first butter knife to slide/rotate the foot into place
The butter knife technique worked for me! I just cracked open the bottom edge of where my little rubber foot had fallen out. (Somehow the plastic was still in there so I was able to stick the foot back in and it works!)
