跳转到主内容
加入维修社区 - 创建账户
Magic Trackpad Rubber Replacement/Reinsertion
你所需要的
    1. Magic Trackpad Rubber Replacement/Reinsertion, Rubber Feet: 步骤 1 中的图像 1,2 Magic Trackpad Rubber Replacement/Reinsertion, Rubber Feet: 步骤 1 中的图像 2,2
      • Unscrew the battery door by turning the screw counter-clockwise with a flat edge screwdriver, coin, plastic opening tool, or fingernail.
      询问修复机器人
      添加评论
    2. Magic Trackpad Rubber Replacement/Reinsertion: 步骤 2 中的图像 1,3 Magic Trackpad Rubber Replacement/Reinsertion: 步骤 2 中的图像 2,3 Magic Trackpad Rubber Replacement/Reinsertion: 步骤 2 中的图像 3,3
      • The rubber buffer consists of two parts: a rigid part made ​​of plastic and the sheath, which is made ​​of rubber.
      • The shape of the foot may not be perfectly spherical, as in the photo. This can occur when a portion of the rubber flap has come out of the notch. When you put it back in, it will become spherical again.
      添加评论
    3. Magic Trackpad Rubber Replacement/Reinsertion: 步骤 3 中的图像 1,3 Magic Trackpad Rubber Replacement/Reinsertion: 步骤 3 中的图像 2,3 Magic Trackpad Rubber Replacement/Reinsertion: 步骤 3 中的图像 3,3
      • Using a spudger or small flathead screwdriver, gently break the seal between the white plastic backing and the metal top near the missing foot opening.
      • Pry up the corner slightly to allow the foot to be replaced.
      • Place the rubber foot back in place.
      • Squeeze closed the backing and metal top (it will snap into place).
      • Click on trackpad to test.
      • Insert the battery and screw the battery cover closed.
      • A foot may again dislodge, for example when you inadvertently move a sheet of paper under the trackpad. Repeat steps as needed to replace.
      添加评论
    4. Magic Trackpad Rubber Replacement/Reinsertion: 步骤 4 中的图像 1,3 Magic Trackpad Rubber Replacement/Reinsertion: 步骤 4 中的图像 2,3 Magic Trackpad Rubber Replacement/Reinsertion: 步骤 4 中的图像 3,3
      • If you want to remove the plastic cover completely, it is better to open it starting from the top.
      • Opening from the top will reduce the risk of breaking any of the clips at the bottom.
      • The cover is attached to the trackpad through rubber glue on the plastic grid and four clips on the bottom.
      • Take your time to slowly open the plastic cover from the top side.
      添加评论
终点
取消:我没有完成这个指南。
179等其他人完成本指南。
revher
于08/17/13注册
4,142 声望
创作了2篇指南
67指南评论
where can i buy the plastic feet?????
Lorraine Hughes - 回复 分享
Yes. Where can I buy the rubber feet?
Rick Sciranko - 回复 分享
I bought mine off Ali Express. There’s quite a few stores on there that sell them. Here’s the one I bought from.
James Sanday - 回复 分享
Found this guide confusing. Here's what worked for me:
1. Place the tip of a butter knife inside the hole and gently lift the plastic high enough to place the tip of another butter knife on the side and hold the plastic up.
2. Remove the first butter knife from the hole. Gently raise the plastic with the second butter knife high enough to slide the foot underneath.
3. Use the first butter knife to slide/rotate the foot into place
Jeremy Johnson - 回复 分享
The butter knife technique worked for me! I just cracked open the bottom edge of where my little rubber foot had fallen out. (Somehow the plastic was still in there so I was able to stick the foot back in and it works!)
Frances Darwin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 50
过去 30 天: 196
总计 114,088
