跳转到主内容
Magellan RoadMate 5250T-LM Battery Replacement
你所需要的
  1. Magellan RoadMate 5250T-LM Battery Replacement, Battery: 步骤 1 中的图像 1,2 Magellan RoadMate 5250T-LM Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove all four 5 mm screws from the back of the device using a Phillips Head screwdriver size 000.
  2. Magellan RoadMate 5250T-LM Battery Replacement: 步骤 2 中的图像 1,2 Magellan RoadMate 5250T-LM Battery Replacement: 步骤 2 中的图像 2,2
    • Open the casing of the device using a plastic opening tool.
  3. Magellan RoadMate 5250T-LM Battery Replacement: 步骤 3 中的图像 1,2 Magellan RoadMate 5250T-LM Battery Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the tape covering the display connector on top of the motherboard.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Battery Replacement: 步骤 4 中的图像 1,2 Magellan RoadMate 5250T-LM Battery Replacement: 步骤 4 中的图像 2,2
    • Pry off the original battery using a spudger to break the adhesive that connects the battery to the back casing.
  5. Magellan RoadMate 5250T-LM Battery Replacement: 步骤 5 中的图像 1,2 Magellan RoadMate 5250T-LM Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the motherboard from the device by unscrewing all three 4 mm screws that are connecting it to the casing with a Phillips Head screwdriver size 000.
  6. Magellan RoadMate 5250T-LM Battery Replacement: 步骤 6 中的图像 1,1
    • Disconnect the original battery from the motherboard by desoldering all three wires that attach it to the motherboard.
    • Click here to refer to iFixit's soldering technique guide for this step.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 13
总计 987
