跳转到主内容
Magellan RoadMate 5236T-LM Speaker Replacement
你所需要的
  1. Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 步骤 1 中的图像 1,3 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 步骤 1 中的图像 2,3 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 2 中的图像 1,3 Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 2 中的图像 2,3 Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 2 中的图像 3,3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 3 中的图像 1,2 Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 3 中的图像 2,2
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
    • Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
  5. Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 5mm screws using a Phillips #000 screwdriver.
  6. Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 6 中的图像 1,3 Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 6 中的图像 2,3 Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove three 5mm screws that hold the motherboard down to the the back panel.
    • Remove the battery, speaker and motherboard. Place them on a flat surface upside down.
  7. Magellan RoadMate 5236T-LM Speaker Replacement: 步骤 7 中的图像 1,1
结论
Felix Muwanguzi
于10/24/16注册
199 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-7, Catania Fall 2016 UMass Dartmouth, Team 4-7, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G7
3 名成员
创作了5篇指南
一条评论
Where can I find a replacement speaker?
Tom Phillips - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 162
