跳转到主内容
Macbook Unibody 型号A1278 电池盖替换
你所需要的
  1. Macbook Unibody 型号A1278 电池盖替换, 电池盖: 步骤 1 中的图像 1,1
    • 笔记本盒盖,然后笔记本底部朝上放置
    • 按下位于底盖右侧的电池盖门闩,当电池盖被提起到可以拿起的程度时就可以放下门闩至与底盖齐平。
    This is not a a1278 unibody MacBook Pro. A1278 MacBooks backs are one solid metal piece not two separate pieces. This guide is for a different MacBook Pro.
    Brad Burgeson - 回复
    This guide isn’t for a pro; it’s a MacBook unibody.
    Nicholas -
    So, it turns out that Apple used the model code A1278 for quite a few different Mac models, including both Pro and non-Pro versions! This guide is for the non-Pro Macbooks. There’s also one for the Pro models with the same A1278 identifier.
    tempelmann - 回复
  2. Macbook Unibody 型号A1278 电池盖替换: 步骤 2 中的图像 1,1
    • 这时如果正常的话握着边缘就能很轻松地拿出盖子
结论
若要组装设备,仅需将教程反着来操作
55等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
laiTM正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
Are there more than one A1278? Mine is the MacBook Pro 13” from 2010, which has no access door, but just a single body shell (613-8316-A)
Martin - 回复
Yes there are multiple machines with the model identifier A1278. In fact all non retina 13“ MacBook Pro models share the same A1278 model identifier as well as the Late 2008 Aluminum MacBook. However only the Late 2008 MacBook has the split access door.
Carl Hauschke -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 63
总计 42,274
