跳转到主内容
Macbook Pro 14" 2023 Lower Case Replacement
你所需要的
  1. Macbook Pro 14" 2023 Lower Case Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Macbook Pro 14" 2023 Lower Case Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    购买
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Macbook Pro 14" 2023 Lower Case Replacement, Unclip the lower case: 步骤 2 中的图像 1,2 Macbook Pro 14" 2023 Lower Case Replacement, Unclip the lower case: 步骤 2 中的图像 2,2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. Macbook Pro 14" 2023 Lower Case Replacement, Release the right clips: 步骤 3 中的图像 1,3 Macbook Pro 14" 2023 Lower Case Replacement, Release the right clips: 步骤 3 中的图像 2,3 Macbook Pro 14" 2023 Lower Case Replacement, Release the right clips: 步骤 3 中的图像 3,3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. Macbook Pro 14" 2023 Lower Case Replacement, Release the left clips: 步骤 4 中的图像 1,3 Macbook Pro 14" 2023 Lower Case Replacement, Release the left clips: 步骤 4 中的图像 2,3 Macbook Pro 14" 2023 Lower Case Replacement, Release the left clips: 步骤 4 中的图像 3,3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. Macbook Pro 14" 2023 Lower Case Replacement, Release the sliding clips: 步骤 5 中的图像 1,3 Macbook Pro 14" 2023 Lower Case Replacement, Release the sliding clips: 步骤 5 中的图像 2,3 Macbook Pro 14" 2023 Lower Case Replacement, Release the sliding clips: 步骤 5 中的图像 3,3
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. Macbook Pro 14" 2023 Lower Case Replacement, Remove the lower case: 步骤 6 中的图像 1,3 Macbook Pro 14" 2023 Lower Case Replacement, Remove the lower case: 步骤 6 中的图像 2,3 Macbook Pro 14" 2023 Lower Case Replacement, Remove the lower case: 步骤 6 中的图像 3,3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2023 Answers community for help.
Chayton Ritter
于08/21/20注册
18,618 声望
创作了102篇指南
团队
Guide Team Guide Team 的会员
Staff
6 名成员
创作了7,844篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 31
过去 30 天: 126
总计 1,842
