简介
本指南仅限私人使用。
你所需要的
即将完成!
如需重新组装您的设备,请按照相反的顺序执行这些指示。
结论
另外一个人完成了本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
you do not need to remove the battery when replacing the hard drive or ram
brilldoctor - 回复
beware not to lift the connector to close of the angle, as the picture suggest it. It might broke the angle. Attack by the middle.
naamol - 回复
Not necessary?
hikkymemo - 回复
Be careful of the corner of the battery cable connector when trying to pry it off with the spudge. I knocked the corner of mine. No operational impact but was not very pleasing!
jljordanweb - 回复
Not necessary, but a good idea, so as to avoid any spurious charges going through the boards...
svenaustx - 回复
@Svenaustx - What could happen if not removing this battery? Worst case? Not a geek on this but did change RAM on my Macbook Pro "15. Can't remember disconneting the battery back then. Shouldn't it be sufficient shutting the Mac off and ensure it has been used for an hour or so before replacing RAM?
Allan Clarke -
i used a metal pry and noticed some sparking when i disconnected the battery. replaced ram. now it wont turn on. did i fry it?
Ian Lynch - 回复
