跳转到主内容
MacBook Pro Retina 2012–2015 Feet Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro Retina 2012–2015 Feet Replacement, Feet: 步骤 1 中的图像 1,2 MacBook Pro Retina 2012–2015 Feet Replacement, Feet: 步骤 1 中的图像 2,2
    • Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
    • Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
  2. MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 2 中的图像 1,2 MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 2 中的图像 2,2
    • Remove any broken or damaged feet.
    • If the foot you are replacing is still intact, you can use your tweezers push it out from the inside.
    • If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
  3. MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 3 中的图像 1,1
    • Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
  4. MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 4 中的图像 1,1
    • Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
  5. MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 5 中的图像 1,1
    • Peel a replacement foot from the plastic backing.
    • The adhesive is fairly strong—make sure that you are peeling the foot up, not tearing the plastic backing.
  6. MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 6 中的图像 1,3 MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 6 中的图像 2,3 MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 6 中的图像 3,3
    • Align the new foot inside the cavity.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • You may want to use a pencil to lightly mark where the alignment nub is located. Be careful not to scratch the lower case with your pencil.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
  7. MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 7 中的图像 1,2 MacBook Pro Retina 2012–2015 Feet Replacement: 步骤 7 中的图像 2,2
    • Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
    • Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Repeat the last seven steps for any remaining broken or worn feet.
结论
3等其他人完成本指南。
Taylor Dixon
于06/26/18注册
67,116 声望
创作了94篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,118
