简介
This motherboard includes all ports on the right side.
你所需要的
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
106等其他人完成本指南。
8指南评论
I haven't tried this (yet). However, one note that might be useful:
Note the heat sink compound on the tops of the CPU, video chip, and whatever the third chip is. You're going to need to clean that off the chips and the mating surface and carefully replace it with new compound. Mac's run hot, so it's important to do this carefully (for better heat conduction.
Buy a good quality thermal grease like "Arctic Silver" or "OCZ Freeze Extreme" (my favorite because its almost as good and easier to use). The instructions assume that you're putting the heat sink down on the CPU, but here you're putting the CPU down on the heat sink, so adjust accordingly.
craigster0 - 回复
Tried that. Rather helpful, but a few suggestions.
Step 18: I would suggest to avoid losen the screws that that fasten the heatsink to the board - unless your intention is to really replace the board or the thermal paste. It is possible to get the board in and out with the heatsink attached, but you may have to remove the fans first. Do not losen the five srews marked red towards the back.
Step 19: the mentioned coloured cable is not always coloured (it is not in my model), do not mistake that cable with the cable to the battery, which is also couloured and also connected to the bottom of the board. It may also be better to remove the left speaker assembly and the WLan card to get to the other end of that cable and disconnect it there.
Would it be possible to replace the logic board of an A1212 with the logic board of an A1261?
Look at Step 14, the connectors seem to be different, at least at first sight. Why do you want to take that risk, by the way?
Waldbaer -
