跳转到主内容
MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement
你所需要的
  1. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 2 中的图像 1,1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
    • Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
    • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
  4. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 4 中的图像 1,1
    • Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-point screw.
    • Remove the last 7.4 mm Tri-point screw securing the battery to the upper case.
  5. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 5 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 5 中的图像 2,2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 6 中的图像 1,1
    • Tilt the battery away from the logic board enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • Pull the battery cable connector away from the center of the logic board.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  7. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement, Left Fan: 步骤 7 中的图像 1,1
    • Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
    • In some models, these T6 Torx screws may be 3.1 mm long.
  8. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 8 中的图像 1,3 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 8 中的图像 2,3 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 8 中的图像 3,3
    • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  9. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 9 中的图像 1,1
    • Lift the left fan out of the upper case.
  10. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement, Logic Board: 步骤 10 中的图像 1,1
    • Remove the three T6 Torx screws securing the right fan to the upper case.
  11. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 11 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 11 中的图像 2,2
    • Use the flat end of a spudger to pry the right fan connector up out of its socket on the logic board.
    • Remove the right fan from the upper case.
  12. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 12 中的图像 1,1
    • Use the flat end of a spudger to pry the AirPort / Bluetooth ribbon cable up off its socket on the logic board.
    • Fold the AirPort / Bluetooth ribbon cable back to keep it out of the way of the logic board.
  13. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 13 中的图像 1,1
    • Disconnect the iSight cable by pulling its connector toward the optical drive opening.
  14. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 14 中的图像 1,1
    • Use the flat end of a spudger to pry the optical drive cable connector up from the logic board.
    • Fold the optical drive cable back to keep it out of the way of the logic board.
  15. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 15 中的图像 1,1
    • Carefully pull the subwoofer/right speaker cable up to lift its connector out of its socket on the logic board.
  16. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 16 中的图像 1,1
    • Use the flat end of a spudger to pry the hard drive cable connector up out of its socket on the logic board.
  17. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 17 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 17 中的图像 2,2
    • Remove the two short Phillips screws securing the small EMI shield to the logic board.
    • Remove the EMI shield from the logic board.
  18. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 18 中的图像 1,1
    • Use the flat end of a spudger to pry the trackpad cable connector up out of its socket on the logic board.
  19. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 19 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 19 中的图像 2,2
    • Use your fingernail to carefully flip up the keyboard ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable straight out of its socket.
  20. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 20 中的图像 1,1
    • Use the flat end of a spudger to pry the battery indicator cable connector up out of its socket on the logic board.
  21. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 21 中的图像 1,3 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 21 中的图像 2,3 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 21 中的图像 3,3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket.
    • Do not pull the cable upward, as the socket is very fragile. Pull the cable parallel to the face of the logic board toward the corner of the upper case.
  22. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 22 中的图像 1,2 MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 22 中的图像 2,2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket.
  23. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 23 中的图像 1,1
    • Remove the following screws:
    • Seven 3.3 mm T6 Torx screws securing the logic board to the upper case.
    • Two 8 mm T6 Torx screws securing the DC-In board to the upper case.
    • Do not remove the logic board yet! There are components on the underside of the logic board attached to the the upper case that must first be disconnected.
  24. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 24 中的图像 1,1
    • Carefully lift the logic board assembly from the left side and work it out of the upper case, minding the port side that may get caught during removal.
    • Do not entirely remove the logic board yet!
  25. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 25 中的图像 1,1
    • Lift the logic board enough to gain clearance and use a spudger to pry the microphone up off the upper case.
  26. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement: 步骤 26 中的图像 1,1
    • Slide the logic board away from the port openings and lift the assembly out of the upper case.
    • Before reinstalling the logic board, it is easiest to press the microphone down into its housing in the left speaker to keep it in place.
    • To avoid ESD damage, be sure to lay your logic board on a soft, static free surface during service.
  27. MacBook Pro 15" Unibody Mid 2010 MagSafe DC-In Board Replacement, MagSafe DC-In Board: 步骤 27 中的图像 1,1
    • Disconnect the DC-In board by pulling its cable toward the heat sink.
    • Pull the cable parallel to the face of the logic board.
结论
65等其他人完成本指南。
4条评论
Excellent walkthrough! This was my first ifixit repair and I was able to successfully replace my damaged magsafe board. The 64-Bit driver kit was the perfect companion to this project and the many more that will come in the future.
Jonathan Daiello - 回复
Thanks for your help! I think something on the mainboard is toast and the computer is a total loss, but it was worth it to take a chance and see if the cheap mag board would fix it. Good guide!
atworkforu - 回复
Good guide - gave me the confidence to have a go - thanks - I would say to others be very gentle with the cable connectors - mine weren’t exactly the same type as shown in the guide - be patient and you’ll work it out.
Balloon Wrangler - 回复
I did the same procedure yesterday replacing a malfunction on magsafe board, just before signing up for Fixit and viewing this document. The walkthrough depicted here is really detailed and very well done. Excellent.
Marco Pellegrinato - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 49
总计 30,429
