简介
Remove the lower case to access most of your MacBook Pro's internals.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
37等其他人完成本指南。
2条评论
For re-assembly, tilt the screw driver slightly at an angle tangent to the case's edge when screwing in the seven 3 mm Phillips screws. Screw the 13 mm screws directly downward. This should ensure better thread engagement.
