简介
Regain recording functionality by replacing a faulty microphone.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
Use the flat end of a spudger to pry the microphone cable connector up off its socket on the logic board.
4等其他人完成本指南。
