跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement
你所需要的
    1. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Lower Case: 步骤 1 中的图像 1,1
      • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
      • Eight 3.0 mm
      • Two 2.3 mm
      添加评论
    2. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 步骤 2 中的图像 1,1
      • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
      • Set the lower case aside.
      添加评论
    1. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Battery Connector: 步骤 3 中的图像 1,1
      • Peel back the warning label covering the battery connector.
      添加评论
    2. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 步骤 4 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 步骤 4 中的图像 2,2
      • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
      • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
      添加评论
    1. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: 步骤 5 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: 步骤 5 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement, Heat Sink: 步骤 5 中的图像 3,3
      • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
      • Slide the spudger underneath the length of the cover, releasing the adhesive.
      • Lift the cover and rotate it off of the heat sink.
      询问修复机器人
      添加评论
    2. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 步骤 6 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 步骤 6 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 步骤 6 中的图像 3,3
      • In the same manner described above, release the adhesive and flip back the heat sink cover on the left fan.
      询问修复机器人
      添加评论
    3. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 步骤 7 中的图像 1,1
      • Remove the following ten screws securing the heat sink to the logic board:
      • Two 2.4 mm T5 Torx screws
      • Six 3.4 mm T5 Torx screws
      • One 5.2 mm Raised Head T5 Torx screw
      • One 3.5 mm T5 Torx screw
      添加评论
    4. MacBook Pro 15" Retina Display Mid 2012 Heat Sink Replacement: 步骤 8 中的图像 1,1
      • Grasping the heat sink from one side, lift the heat sink off of the MacBook Pro, pulling it free from the computer.
      • The thermal paste may make it difficult to remove the heat sink. Pull the heat sink off gently but forcefully to avoid damaging any components on the logic board.
      • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink. See our Applying Thermal Paste guide for further instructions.
      添加评论
结论
取消:我没有完成这个指南。
41等其他人完成本指南。
Brett Hartt
于04/12/10注册
132,329 声望
创作了144篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了82,057篇指南
8指南评论
would doing this void the warranty?
sakada - 回复 分享
Hello everybody!!! I tried to follow this guide... I removed the bottom case, no problem... but when it was the time to remove the upper 2.4mm T5 torn screw... it stripped and now i cannot remove it! How can i remove that screw?
And if this is not enough one of the 3mm pentalobe screw of the bottom stripped too! so what can i do?!? please help me!
Sorry for my bad english
Shaggot96 - 回复 分享
I'm sorry to hear that! Try checking out this stripped screw guide and reading through this Answers post. Hope this helps with your repair!
Sam Goldheart - 回复 分享
I won't call this moderate but rather easy instead, seems like ifixit expect that easy is something you just unplug without even open the computer
Benjamin H - 回复 分享
Where can I get new screws if I want to replace them?
Boro J. - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 116
总计 46,066
