跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement
你所需要的
  1. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
    添加评论
  2. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 2 中的图像 1,1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
    添加评论
  3. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement, Battery Connector: 步骤 3 中的图像 1,1
    • Peel back the warning label covering the battery connector.
    添加评论
  4. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 4 中的图像 1,2 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 4 中的图像 2,2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    添加评论
  5. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement, AirPort/Camera Cable: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
    添加评论
  6. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 6 中的图像 1,1
    • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
    • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
    • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
    添加评论
  7. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 7 中的图像 1,3 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 7 中的图像 2,3 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 7 中的图像 3,3
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
    添加评论
  8. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 8 中的图像 1,3 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 8 中的图像 2,3 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 8 中的图像 3,3
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    添加评论
  9. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement, I/O Board Cable: 步骤 9 中的图像 1,3 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement, I/O Board Cable: 步骤 9 中的图像 2,3 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement, I/O Board Cable: 步骤 9 中的图像 3,3
    • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
    • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
    • During reassembly, connect this end first, as it does not flex.
    • In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
    • Remove the I/O Board cable from the MacBook Pro.
    添加评论
  10. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement, Airport Card: 步骤 10 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
    添加评论
  11. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 11 中的图像 1,2 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 11 中的图像 2,2
    • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
    • Pull the AirPort card parallel out of its connector on the logic board to remove it.
    添加评论
  12. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 12 中的图像 1,2 MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 12 中的图像 2,2
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board.
    添加评论
  13. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 13 中的图像 1,1
    • Remove the following three screws securing the right fan to the logic board:
    • One 4.4 mm T5 Torx screw
    • One 3.9 mm T5 Wide Head Torx screw
    • One 5.0 mm T5 Torx screw with 2 mm collar
    添加评论
  14. MacBook Pro 15" Retina Display Early 2013 Right Fan Replacement: 步骤 14 中的图像 1,1
    • Lift and remove the right fan out from the MacBook Pro.
    • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
20等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,418 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了25,930篇指南
4指南评论
doesn't look too bad, my right fan is making a terrible sound, I'm debating if I should bring it to apple or if I should just replace it myself
aaronchasemusic - 回复 分享
pretty easy guide. i replaced the left fan recently, so i decided to do the right as well since it had been making the same grinding noise, albeit not quite as loud. the fans themselves were pretty clean, i’ve typically use a blast of compressed air to dust them out about once a month over the almost 5 years i’ve owned this MBP.
i skipped steps 3-4-5. and using some of the comments as guidance i was able to take a few short cuts and have the fan replaced in about 20 minutes. powered up the MB without the back cover just to make sure the fan would spin, it did, checked to make sure everything worked, internet, BT connection, camera etc, powered down, screwed on the back cover and done.
MacProUser - 回复 分享
easy and fast. it took me 10 min to replace.
dmitrii-bocharov - 回复 分享
Replaced batteries and RIGHT FAN. Made all connections. LEFT FAN runs and won't stop, whether connected with charge cord or running on batteries. Laptop will NOT start up. Disconnected LEFT FAN to save batteries. I'M STUMPED! :-(
keith maxwell - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 97
总计 21,723
