当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Remove the following 15 screws:
One 4.4 mm black Phillips screw to the right of the ram slot.
Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
One 6.2 mm black T6 Torx screw on the right side of the left fan.
Five 9.4 mm silver T6 Torx screws securing the left and right fans.
这个步骤还没有翻译 帮忙翻译一下
Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
Place the fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
6等其他人完成本指南。
