简介
Use this guide to replace the MagSafe DC-in board.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
How do you get that battery connector back on? Do you just press it in back in place after you're done?
yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
Use a spudger to pry up the fan connector out of its socket on the logic board.
Any tips on how to solder it back on? I made the same mistake.
Hi Hector, how did you put it back?
I broke mine too and carefully glued it back in but now the fan isn't working... But I don't know if it's because of this or because it does not need to switch on as I also changed my hard drive from HD to SSHD Hybrid.
Thanks
I did a terrible mistake when I try to remove the fan connector socket form the logic board I accidentally pop out the connector from the board.. I am not expert in soldering so big problem for me. What should I do?
that you dont have to break off the fan connector).It is possible to leave the fan attached to the logic board by the single torx screw (on the right hand side in the image below). So h
The image is very misleading. This is why many people are breaking their connectors. Please correct this and make it VERY clear that one has to put the spudger straight behind the cables, NOT behind the connector, as shown in the pic.
I agree with Giunia. I just broke my fan socket off the board too
vejdani -
I agree with Giunia. Just broke my fan socket off the board >_<
Thankfully there is a helpful guide in the comments on this post for fixing the socket in the likely event that you snap the sucker clean off like I did:
i also broke the fan connector off from my board, currently attempting to glue down with super glue. i agree with the others. photo could be updated to show spudger behind the connector wires (not at the corner of the connectors base as it currently, misleadingly shows). and perhaps even another line drawing or illustration showing how this fan connector fits into its socket on the board like a foot being put into a shoe. toes down first, heel with wires clicks in last. coming out the heel of the connector with wires comes up and out of the shoe first, then the toes. be careful out there.
I see people talking about gluing it back. This is a connector that carries electricity, the electricity is what make the fan turn, not magic. The connector needs to be soldered back, not glued., as glue doesn’t conduct electricity. Any attempt at gluing it back will make further reparations very complicated, as the reparator will have to try to remove the glue you put in order to be able to solder back.
Long story short, if you think gluing it back is a good idea, you should not be attempting this repair (changing the keyboard) in the first place.
Remove the following three screws:
One 7 mm T6 Torx screw
Two 5.4 mm T6 Torx screws
Si comme moi les vis sont fourrés, ne pas hésiter a forer la tête avec une mèche de 2-3mm (ne doit pas être plus gros que le corps de la vis pour ne pas tout abîmer). Le seul soucis de pose au remontage (pas de vis du coup) mais une fois la corvée remise, pas de soucis.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Gently pull the display data cable connector away parallel to the board.
On my system the pad on top of the connector was shifted making the bracket difficult to rotate into the up position. The bracket looks like a handle so my first instinct was to pull it straight up. Big mistake. I ended up popping the brass guard off the connector on the logic board. The instructions could benefit from an arrow indicating the direction to pull and rotation of the bracket.
The same thing happened to me. What did you do when you reassembled? thx Alan
Everything went fine, but now I cannot get the connector back - it seems that I'm doing everything in reverse order, but i doesn't fit
Remove the following two screws securing the display data cable bracket to the upper case:
One 8.6 mm Phillips
One 5.6 mm Phillips
Lift the display data cable bracket out of the upper case.
Same problem here but with the 5.6 mm one. In fact, that screw was slightly different from a phillips, it seems a tiny torq-set screw. Is that possible? Anyone else had a similar problem? I stripped it out using a phillips 00 that worked perfectly removing all the other phillips screws...
Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
How does this thing reconnect? there are no visible clips, hooks, pins, nothing. Adhesive?
My subwoofer connector cam off the logic board. I guess I’ll see if there is no issue putting it back together with a working sub woofer
Greg Zulli - 回复
Haha on the picture the person broke it! You should take it off same way you take off the fan connector. This illustrates what happens when you do it wrong.
Those white spots are components, not the solder point for the connector.
I managed to break the connection to the mother board. I think when you remove the connection the bottom part should remain so as to reconnect. Maybe a little more info here would help. In the meantime my only option is to solder a new connection. Anybody tried this with a fine pointed soldering iron? Solder fine cables direct to the motherboard? By the way I don’t appreciate the haha from Albert.
The first time i tried this on a MBP 13 I broke the connector form the board. It should be noted that you have to be very careful in this step, as the plug fits very tightly and you can easily use too much force to tear the connector from the board. Use a second spudger to hold down the connector at its border and try very gently using a second spudger to move the plug out of the connector upwards.
Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
As mentioned, the socket can be easily damaged when re-inserting it. I didn't care enough and one pin was damaged. Wifi was not detected.
Hopefully the pin was not broken (only bent). Putting it back in its correct position, the wifi re-appeared.
Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
Use your spudger to slide the keyboard ribbon cable out of its socket.
Sometimes spulger is not the best tool to slide the cable out. If it is difficult to slide, try two toothpicks to pull the cable from two sides simultaneosly.
As Mateo said, replacing the zif cable is NOT easy, and in this case, will leave you with a computer that won't power on- this cable connects the power button. I learned a trick somewhere for dealing with these cables- put a piece of good sticky tape on the cable, and use it to pull it back into the connector. Works every time.
Yeah! The tape trick worked for me. Thanks!
Thank you Steve, it’s works perfectly.
Does anyone have pictures showing how to reinstall the keyboard and backlight cable?
I think this is why my MacBook Pro won’t turn on. I might have not re-inserted the ZIF cable correctly. Thank you!
Can some show me a picture of how they did it with tape method
Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
Be very careful while taking this black tape off. I accidentally broke the chip off the motherboard and so my keyboard is not backlit any more.
Asim Akath - 回复
Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
Easy to take out Zif cable but can't seem to get it back in again.
Be especially careful as my hole socket detached from the board. It would have helped to vertically press the socket to the board with the tip of a spudger. Thus partially blocking the strap, you can first peel the free end, then change position and peel the rest. Slide the ribbon cable perfectly horizontally.
I had the same issue of trying to get the ZIF cable back in but found that if I used a piece of scotch tape, it worked. I followed this guide. MacBook unibody keyboard ribbon cable won't go in
A reassembly trick that works for me is to use some 3/4" blue painters tape to stick to the very back (lower end) of the ribbon cable so I can pull it up and back before locking the cam. Trying to get a good grip without cutting, or crimping the ribbon means no tweezers or pliers can be used.
Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
If you’re swapping top cases, you might need to remove the battery indicator from the case and swap it to the replacement top case. It attaches with three very tiny Phillips screws. I wasn’t aware that my replacement top case didn’t have this part and got confused when reversing the steps to reassemble and I didn’t have this connector. I had to take the battery back out in order to swap the indicator over.
Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
on the Australian/Asia version speaker cable is located underneath the logic board.
Guys, I replaced the microphone and the new one doesn’t have glue on, so I had to use superglue… did I make a mistake??
ilaria.miniussi NEVER go full superglue :)
Remove the following Tri-point screws securing the battery to the upper case:
One 5.5 mm Tri-point screw
One 13.5 mm Tri-point screw
Lift the battery out of the upper case.
Why not do this step near the start? Would make it easier to replace the ribbon cables in step 12, 13 and 14
Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
Pull the logic board away from the side of the upper case and remove it, minding the DC-In board that may get caught.
Be careful while taking the board out, as the heatsink usually is caught by the optic drive.
Shouldn’t this be Step 22? i.e. you can only remove the logic board after disconnecting the cables.
Disconnect the DC-In board by pulling its connector away from the socket on the logic board.
74等其他人完成本指南。
12条评论
The Tri-wing Y1screwdriver suggested for this procedure is too big for the removal of the battery screws. I completed replacing the DC in board without removing the battery.
I have just tested several of those drivers from our shelf in 3 different MacBooks we have here with tri-wing type screws, and they are all a perfect fit. I have sent you an email to try and find out why your driver did not fit, you may have a mid 2009 model with pentalobular screws instead?
Thanks! Guide was wonderful! I wish there had been a bit more information about the proper routing of the dc-in cable as the first time I put it back together I accidentally routed the cable on the outside of the mother board riser which made it impossible to seat the display cable hold down clamp properly. I had to re-remove the main board in order to get the dc-in cable on the other side of the riser. Not a biggie, but a note on that step would be helpful. Thanks again!!
To Joey Joe:
I had the same problem, turned out the keyboard zif cable wasn't all the way seated. It can be tricky to get it seated, I use a dental pick to pull up on the cable while guiding it into the slot.
Good luck
maccentric - 回复
Ok this guide was killer. Thank you so much. My only issue is this: Now that i've finished reinstalling everything and fixing my problem- the monitor will not illuminate.. I have Start-up tone and backlit keyboard- but no display? Checked the display connector and it's as seated as it will ever be. Any tips?
Ok, I am getting power, display comes on, doesn't actually boot. The screen stays white, no start-up sound, fan comes on and stays on. Please help
I finished the steps and it worked. The battery indicator only showed a % at the login screen so I did a SCM reset. Did not fix the problem. But turned the charge light to orange instead of continues green. Then after an hour or so the light went out and the battery didn't charge anymore plus the macbook didn't get any power from just the cable as well.
Any ideas?
Sean Stols - 回复
Before I go through this procedure I would like to get input if I should move forward with the DC-IN replacement:
- charger cable does not light green/orange thus no charge
- when charger attached, the battery indicator shows that it is being charged but charge will not increase charge nor decrease.
- replaced charger still no charge
- SMC reset made no difference
- Side charge lights when charger cable is inserted/release DOES work (also with push button)
- replaced battery still no charge
- new battery did power up laptop and Mac OS read charge properly but again no charge
- WEIRD: If I power the laptop and have the charger cable it does not drain the battery but will not increase charge! For example I left the laptop on for 2 hours and it remained at the same battery charge. If I removed the charger the battery would drain.
Sounds like I should go for it however it is pretty complicated however I did completely did an iMac. Thanks for the input.
i have exactly your problem, i changed dc-in but no luck ☹️ when i connect charger to laptop, it has no light like you said, i thought it was dc-in but replacing it with a new one didn’t help
vejdani -
I have the exact same issue. We’re you able to figure out what needed to be fixed?
This DC in board is compatible com macbook pro 15” early 2011?
Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
David Kilbridge - 回复
Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
mastover - 回复
I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
adlerpe -
That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
joyitsjennie -
Great idea and one I use often
Thomas Overstreet -
Excellent idea! Thanks for sharing it here.
Laura Sharkey -
I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
valentinedhdh - 回复
