当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
将相机线从插座中水平滑出。
如果你在主板上看见了一个粘连的小塑料片(固定器) 阻碍相机线拉开,请小心地揭掉。如果有必要,也可以用吹风机或热风枪施加一些微热来使粘合剂软化。请勿 尝试在未揭下塑料片的情况下强行断开相机线。
如果仍无法拔出,请使用撬棒的尖端小心地推接口的每一侧。从一侧交替到另一侧,轻轻地将接口从其插座中“走出来”。
39等其他人完成本指南。
5条评论
What is the circuit board under the clutch? I broke off one of the pieces putting the clutch back on.
That is the airport card and its antennae.
Is this the same process to follow for replacing a clutch cover on a MacBook Pro 13" mid-2012 model?
seanhelmes - 回复
I used this guide for my mid-2012 model (because I thought it was a 2010). It was very similar. The Torx screws were a T7 instead of a T6 and the subwoofer connects with the airport card (instead of the airport card being inside the clutch). I suspect there is a more specific guide on this site. :)
Nicely documented. It was easy to follow and the job went well. Thank you!
