跳转到主内容
MacBook Pro 13" Unibody Late 2011 Battery Replacement
你所需要的
视频概述
  1. MacBook Pro 13" Unibody Late 2011 Battery Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Late 2011 Battery Replacement: 步骤 2 中的图像 1,2 MacBook Pro 13" Unibody Late 2011 Battery Replacement: 步骤 2 中的图像 2,2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Late 2011 Battery Replacement, Battery Connection: 步骤 3 中的图像 1,2 MacBook Pro 13" Unibody Late 2011 Battery Replacement, Battery Connection: 步骤 3 中的图像 2,2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Late 2011 Battery Replacement: 步骤 4 中的图像 1,1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Late 2011 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Remove the following two screws:
    • One 5.6 mm Tri-point screw
    • One 13 mm Tri-point screw
  6. MacBook Pro 13" Unibody Late 2011 Battery Replacement: 步骤 6 中的图像 1,1
    • Carefully peel the battery warning label off the upper case between the battery and the optical drive.
    • Do not remove the label from the battery.
  7. MacBook Pro 13" Unibody Late 2011 Battery Replacement: 步骤 7 中的图像 1,1
    • Use the attached plastic pull tab to remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
结论
318等其他人完成本指南。
Phillip Takahashi
于08/22/11注册
86,704 声望
创作了87篇指南
8条评论
Many thanks to Phillip and the other contributors who put this guide together. My late 2011 MacBook Battery was headed downhill fast. Having used IFixit before, I headed back to the site and found the parts and help that I needed. My new battery arrived two days after placing the order and I went to work. Everything went smooth as silk(again thanks to some IFixit tools, etc.)and I was up and running in no time. Thanks for this great site and for encouraging do-it-yourself repairs with great guides. Hooray to all who like to fix things and boo to manufacturer who design products that make this difficult. Cheers and keep up the great work. Lowell Allen, May 26.
lowellallen2433 - 回复
Thanks a lot, was great help and needed this greatly for one of my macbook.
Best regards from,
http://www.handymandream.com/
Handyman Dream - 回复
Replacing the original battery was easy, but the replacement battery loses a charge very fast.
20 minutes, I’ve lost 11% charge.
Alex - 回复
Thx a lot to everyone at iFixit, now my MacBook Pro Unibody Late 2011 can take a second breath
Franck Bourgeois - 回复
Thanks for the easy to follow instructions! My battery install kit did not come with a spudger, so I used a plastic knife and my finger nails. I was careful to make sure the little seated edges didn’t break off (that’s when I transitioned to my nails).
Christi Ruby - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 121
过去 30 天: 492
总计 208,086
