跳转到主内容
MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement
你所需要的
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 3 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 3 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 3 中的图像 3,3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  3. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Battery Connector: 步骤 4 中的图像 1,1
    • Remove the plastic cover adhered to the battery contact board.
  4. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  5. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 6 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 6 中的图像 2,2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  6. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  7. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 8 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 8 中的图像 2,2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  8. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Battery Contact Board: 步骤 9 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Battery Contact Board: 步骤 9 中的图像 2,2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  9. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Heat Sink Assembly: 步骤 10 中的图像 1,1
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  10. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, I/O Board Data Cable: 步骤 12 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, I/O Board Data Cable: 步骤 12 中的图像 2,2
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
  11. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 13 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 13 中的图像 2,2
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
  12. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 14 中的图像 1,1
    • Lift and remove the I/O board data cable from the MacBook Pro.
  13. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, iSight Camera Cable: 步骤 15 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, iSight Camera Cable: 步骤 15 中的图像 2,2
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
  14. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 16 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 16 中的图像 2,2
    • Move the iSight camera cable aside.
  15. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Right Fan: 步骤 17 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Right Fan: 步骤 17 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Right Fan: 步骤 17 中的图像 3,3
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the right fan ribbon cable straight out of its socket on the logic board.
  16. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 18 中的图像 1,1
    • Remove the three 3.1 mm T5 Torx screws securing the right fan to the logic board assembly.
  17. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: 步骤 19 中的图像 1,1
    • Lift and remove the right fan out of the upper case.
结论
7等其他人完成本指南。
一条评论
During reassembly, installing the shouldered screw in step 5 caused a shock and fried my computer.
Ian - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 4,853
