跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement, Battery Connector: 步骤 1 中的图像 1,1
    • Remove the plastic cover adhered to the battery contact board.
  2. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 步骤 2 中的图像 1,1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  3. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 步骤 3 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 步骤 3 中的图像 2,2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  4. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 步骤 4 中的图像 1,1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  5. MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 步骤 5 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Battery Connector Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 251
