当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Remove the following screws securing the battery connector board to the logic board:
Two 2.8 mm T6 Torx screws
One 7.0 mm T6 Torx shouldered screw
Carefully lift the battery connector board up off the logic board.
It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
Do not fold the board completely over, or crease the cables, as this may damage the battery.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
