简介
Use this guide to replace the right fan duct.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Remove the following screws securing the heat sink to the logic board assembly:
One 2.4 mm Phillips #00 screw
One 3.4 mm T5 Torx screw
Four 2.7 mm T5 Torx screws
Lift and remove the heat sink up off the logic board assembly.
另外一个人完成了本指南。
