简介
使用这份指南更换触控板。
你所需要的
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
请按逆序操作重组你的设备。
46等其他人完成本指南。
由衷感谢以下译者:
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
16指南评论
I have a non clicking trackpad in a mid 2014 chassis, i brought it to the mac store and they say they found liquid damage throughout the computer. weather i believe them is besides the point it is a backup machine and I am not going to spend $700 to clean it out. There doesn't seam to be any trackpads for sale on here. Are they available?
peteuliana - 回复
Just replaced the trackpad on a Macbook Pro A1502. The customer had used the item very little and the trackpad had just failed completely. I found a seller on ebay with a brand new part and went about replacing it. The pentolope screws should have been no problem but one was cross threaded and would not come out. We had to drill it out. Big pain in the butt. Having swapped trackpads in Macbooks before this by comparison was much harder. The battery is glued in but upon further inspection it looks to have been designed to screw in and even has screw holes in the chassis and covered screw holes in the battery. This design seems to go along with the throw away mentality of apple. Apple store said water damage but there was none at all. They wanted 400$. The previous Macbook model they year before had recalled Trackpad issues but not this one???. Really crappy Apple dropped the ball on this one accusing customers of damage and doing nothing to replace a defective part. Thank You for the great fix it!!
7/7/2016. I took my 15" retina to the Genius Bar at the Grove where I bought it 3 years ago, as the pointer was jumping around. It would settle down sometimes, then would act up again. A readout showed that the extreme rhs of the pad was not functioning. Had to leave it. Could not open and fix it at home. Was told this was a unibody, and the entire top of the case needs to be replaced. Will cost me $310 plus tax, and 4 days. They sure don't want us to fool with it!
I've a question. At first I want to say, my English is not the best but I hope you understand me and anyone can answer my question. I've also a problem with the trackpad and I studied this guide a lot. I will start in a few days to try to fix this by replacing the trackpad. The only question I have is, that when I have replaced the trackpad, does I have to use some new glue to stick the battery back in the macbook. Or will the glue which is already on the battery be enough ? I found some glue on amazon which u can use for iPhone displays or something like this and I'm probably going to use this one. Has anybody replaced his trackpad and could give me an answer ? Thanks in advance.. :)
Hello!! I have a Macbook Pro retina 13"(mid 2014) (model:A1502). Yesterday I took my mac to the technical service because the mouse is not working well, and I did'nt know if the problem was software or the trackpad.
They say it's the trackpad, but they should change the whole topcase, and it would cost me almost $ 700 to repair. They say that in this model can not be changed only the trackpad!!! From what I'm seeing here they did not tell me the truth.
How or where can I get a trackpad of this model to solve my problem? Amazon? How do I look for it and how much can it cost? Thanks a lot!!
