跳转到主内容
MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement
你所需要的
  1. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: 步骤 2 中的图像 1,2 MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: 步骤 2 中的图像 2,2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement, Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: 步骤 4 中的图像 1,1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement, Logic Board Bracket: 步骤 6 中的图像 1,1
    • Remove the two small Phillips screws securing the logic board bracket to the upper case.
  7. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: 步骤 7 中的图像 1,1
    • Lift the logic board bracket out of the upper case.
  8. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement, Trackpad Control Cable: 步骤 8 中的图像 1,1
    • Use a spudger to pry trackpad control cable connector up off the logic board.
  9. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: 步骤 9 中的图像 1,1
    • Use the pointed end of a spudger to flip up the retaining flap on the trackpad control cable socket.
  10. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: 步骤 10 中的图像 1,2 MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: 步骤 10 中的图像 2,2
    • Peel the trackpad control cable off the adhesive securing it to the upper case.
    • Pull the trackpad control cable out of its socket.
结论
5等其他人完成本指南。
一条评论
Hi, I was wondering if it's possible to remove the button pad on this model Air, and just install a regular trackpad like the ones in the Macbook Pro Unidbody's and up? Can someone let mek now if that is possible or do you need that click strip in order for it to function properly?
Jabran - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 20,953
