简介
Use this guide to replace a faulty or broken display on your MacBook Air 13" Early 2017.
你所需要的
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Use the flat end of a spudger to pry each of the antenna connectors up from their sockets on the AirPort/Bluetooth card.
27等其他人完成本指南。
5条评论
Thank you so much! I fixed my Macbook Air display! I feel like a champion lol
My MacBook air screen needed to be replaced. There were lines vertical and horizontal. I decided to replace the screen. Got everything put back together from the directions up top. Everything worked except the screen stay black. I hooked the MacBook up to a second screen to make sure. I decided maybe it was a broken replacement so I put the old one back and its also a blank screen also. Before I took the MacBook apart the screen and apple logo both lit up and now I cant get the old screen to come on.
