跳转到主内容
MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement
你所需要的
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Battery Connector: 步骤 3 中的图像 2,2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  3. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 步骤 4 中的图像 1,2 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  4. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: 步骤 5 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  5. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: 步骤 6 中的图像 1,2 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: 步骤 6 中的图像 2,2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
结论
9等其他人完成本指南。
Adam O'Camb
于04/11/15注册
177,503 声望
创作了418篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 58
过去 30 天: 254
总计 6,147
