跳转到主内容
MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement
你所需要的
  1. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Remove the screws securing the lower case: 步骤 1 中的图像 1,1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Remove the lower case: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source. To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Disconnect the battery: 步骤 3 中的图像 1,1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: 步骤 4 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Remove the USB-C board: 步骤 5 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement, Remove the USB-C board: 步骤 5 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector bracket.
    • Remove the USB-C connector bracket.
  6. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: 步骤 6 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  7. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: 步骤 7 中的图像 1,1
    • Use a T4 Torx driver to remove the two 2.9 mm screws securing the USB-C board.
  8. MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement: 步骤 8 中的图像 1,1
    • Remove the USB-C board.
结论
4等其他人完成本指南。
Adam O'Camb
于04/11/15注册
180,974 声望
创作了416篇指南
一条评论
would the steps be the same for late 2016 13 inchs? i don't see a guide for that. also why this so much easier than 2015 guide which is 37 steps lol
Xiaolu Zhu - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 133
总计 4,931
