跳转到主内容
MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement
你所需要的
  1. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement, Remove the screws securing the lower case: 步骤 1 中的图像 1,1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement, Remove the lower case: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source. To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement, Disconnect the battery: 步骤 3 中的图像 1,1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 4 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement, Disconnect the antenna bar: 步骤 5 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement, Disconnect the antenna bar: 步骤 5 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  6. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 6 中的图像 1,3 MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 6 中的图像 2,3 MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 6 中的图像 3,3
    • Insert the point of a spudger under one of the antenna cables close to the connector.
    • Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  7. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 7 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 7 中的图像 2,2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  8. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 8 中的图像 1,2 MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 8 中的图像 2,2
    • Use the flat end of a spudger to pry up the display cable connector.
  9. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement: 步骤 9 中的图像 1,1
    • Use a T5 Torx driver to remove the following screws:
    • Four 7.4 mm screws
    • Two 4.5 mm screws
  10. MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement, Remove the antenna bar: 步骤 10 中的图像 1,3 MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement, Remove the antenna bar: 步骤 10 中的图像 2,3 MacBook Air 13” Retina Display Late 2018 Antenna Bar Replacement, Remove the antenna bar: 步骤 10 中的图像 3,3
    • Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
    • You may encounter resistance from the clips in the middle of the antenna bar holding it in the case. You may pull hard without damaging anything as long as you pull straight up, perpendicular to the case.
    • Remove the antenna bar.
结论
Adam O'Camb
于04/11/15注册
181,064 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 56
总计 1,982
