跳转到主内容
加入维修社区 - 创建账户
MacBook Air 11" Mid 2013 Right Speaker Replacement
你所需要的
  1. MacBook Air 11" Mid 2013 Right Speaker Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
    添加评论
  2. MacBook Air 11" Mid 2013 Right Speaker Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    添加评论
  3. MacBook Air 11" Mid 2013 Right Speaker Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2013 Right Speaker Replacement, Battery Connector: 步骤 3 中的图像 2,2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
    添加评论
  4. MacBook Air 11" Mid 2013 Right Speaker Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
    添加评论
  5. MacBook Air 11" Mid 2013 Right Speaker Replacement: 步骤 5 中的图像 1,1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    添加评论
  6. MacBook Air 11" Mid 2013 Right Speaker Replacement, Right Speaker: 步骤 6 中的图像 1,1
    • Use the tip of a spudger to de-route the right speaker cable from the channel cut into the logic board.
    询问修复机器人
    添加评论
  7. MacBook Air 11" Mid 2013 Right Speaker Replacement: 步骤 7 中的图像 1,1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry upward from beneath the wires.
    询问修复机器人
    添加评论
  8. MacBook Air 11" Mid 2013 Right Speaker Replacement: 步骤 8 中的图像 1,2 MacBook Air 11" Mid 2013 Right Speaker Replacement: 步骤 8 中的图像 2,2
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
    询问修复机器人
    添加评论
  9. MacBook Air 11" Mid 2013 Right Speaker Replacement: 步骤 9 中的图像 1,1
    • Remove the right speaker from the upper case.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Sam Goldheart
于10/18/12注册
477,418 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了25,930篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 76
总计 2,408
