本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace a damaged heat sink or its thermal paste.
你所需要的
在这个步骤中使用的工具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
7等其他人完成本指南。
一条评论
Hello. When I tried to reinstall the IO board, I noticed that the sounds werent detected. The microphone too. The connectors were installed. Then when i plug the magsafe charger, power source is power adapter, but not charging. The USB port doesnt detect any flashdrives.
What may seem to be the problem and how can I fix it? Thank you. I’m on my last 80% battery life. Please help.
