跳转到主内容
Mac mini Late 2018 Disassembly
你所需要的
  1. Mac mini Late 2018 Disassembly, Out of the box: 步骤 1 中的图像 1,2 Mac mini Late 2018 Disassembly, Out of the box: 步骤 1 中的图像 2,2
    • So here it is, exactly the same form factor as the previous Mac mini, but now in Space Gray
  2. Mac mini Late 2018 Disassembly, Lets flip it over: 步骤 2 中的图像 1,3 Mac mini Late 2018 Disassembly, Lets flip it over: 步骤 2 中的图像 2,3 Mac mini Late 2018 Disassembly, Lets flip it over: 步骤 2 中的图像 3,3
    • Once flipped over, a familiar black cover is revealed.
    • Pry open the lid to release it from the three large screws
    • The lid had a soft foam inside to dampen the vibrations of the beefed up fan
  3. Mac mini Late 2018 Disassembly, Take off the metal cover: 步骤 3 中的图像 1,2 Mac mini Late 2018 Disassembly, Take off the metal cover: 步骤 3 中的图像 2,2
    • The lid is secured with the same TR6 screws as the 2014 model
  4. Mac mini Late 2018 Disassembly, Reveal the innards: 步骤 4 中的图像 1,2 Mac mini Late 2018 Disassembly, Reveal the innards: 步骤 4 中的图像 2,2
    • The antenna cable is very short, so watch out; rotate the cover to reveal the internals
  5. Mac mini Late 2018 Disassembly, Antenna cable: 步骤 5 中的图像 1,2 Mac mini Late 2018 Disassembly, Antenna cable: 步骤 5 中的图像 2,2
    • The antenna cable is held down with a little TX6 screw
    • It has a tiny washer to make sure no stress is applied to the cable
  6. Mac mini Late 2018 Disassembly, Take off the fan: 步骤 6 中的图像 1,3 Mac mini Late 2018 Disassembly, Take off the fan: 步骤 6 中的图像 2,3 Mac mini Late 2018 Disassembly, Take off the fan: 步骤 6 中的图像 3,3
    • The fan has four identical TX6 screws holding it down
    • The screws go trough a rubber tube to reduce vibration
  7. Mac mini Late 2018 Disassembly, Take the fan out: 步骤 7 中的图像 1,3 Mac mini Late 2018 Disassembly, Take the fan out: 步骤 7 中的图像 2,3 Mac mini Late 2018 Disassembly, Take the fan out: 步骤 7 中的图像 3,3
    • Underneath the fan the connector pops off easilly
    • The fan feels solid. Much better than previous models
  8. Mac mini Late 2018 Disassembly, Next, the motherboard: 步骤 8 中的图像 1,3 Mac mini Late 2018 Disassembly, Next, the motherboard: 步骤 8 中的图像 2,3 Mac mini Late 2018 Disassembly, Next, the motherboard: 步骤 8 中的图像 3,3
    • Now, lets take out the motherboard
    • Massive (for the mini) TX10 screws secure the motherboard to the chassis
  9. Mac mini Late 2018 Disassembly, Unplug some wires: 步骤 9 中的图像 1,2 Mac mini Late 2018 Disassembly, Unplug some wires: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • The power supply can be unplugged by as many wires as possible between your iFixit tweezers and pull upwards
    • Also take off the tiny power led connector
  10. Mac mini Late 2018 Disassembly, Motherboard out: 步骤 10 中的图像 1,2 Mac mini Late 2018 Disassembly, Motherboard out: 步骤 10 中的图像 2,2
    • Slide the motherboard out by gently applying pressure to the heatsink
  11. Mac mini Late 2018 Disassembly, Details on the design: 步骤 11 中的图像 1,3 Mac mini Late 2018 Disassembly, Details on the design: 步骤 11 中的图像 2,3 Mac mini Late 2018 Disassembly, Details on the design: 步骤 11 中的图像 3,3
    • Some interesting design choices made here. A full size CMOS battery
    • The wifi wiring runs underneath the large speaker
    • The power button is attached to a ultra flat cable that runs in an arc along the heatsink
  12. Mac mini Late 2018 Disassembly, Motherboard underside: 步骤 12 中的图像 1,3 Mac mini Late 2018 Disassembly, Motherboard underside: 步骤 12 中的图像 2,3 Mac mini Late 2018 Disassembly, Motherboard underside: 步骤 12 中的图像 3,3
    • We flip over the motherboard to see a massive amount of tiny components
    • Also some familiar pieces of foam all over the place
  13. Mac mini Late 2018 Disassembly, Memory cover: 步骤 13 中的图像 1,3 Mac mini Late 2018 Disassembly, Memory cover: 步骤 13 中的图像 2,3 Mac mini Late 2018 Disassembly, Memory cover: 步骤 13 中的图像 3,3
    • But now what we are all here for. The RAM
    • Four TX5 screws holt it down
  14. Mac mini Late 2018 Disassembly, Slide off the cover: 步骤 14 中的图像 1,3 Mac mini Late 2018 Disassembly, Slide off the cover: 步骤 14 中的图像 2,3 Mac mini Late 2018 Disassembly, Slide off the cover: 步骤 14 中的图像 3,3
    • The memory cover slides off at an angle
  15. Mac mini Late 2018 Disassembly, Rubber spacers: 步骤 15 中的图像 1,2 Mac mini Late 2018 Disassembly, Rubber spacers: 步骤 15 中的图像 2,2
    • These rubber parts will be a pain to put back on later.
    • There are tiny pieces of rubber in it that need to slide into the metal clips holding the memory in place
  16. Mac mini Late 2018 Disassembly, Memory out: 步骤 16 中的图像 1,3 Mac mini Late 2018 Disassembly, Memory out: 步骤 16 中的图像 2,3 Mac mini Late 2018 Disassembly, Memory out: 步骤 16 中的图像 3,3
    • The memory itself sits upside down in its sockets
    • The springs are very strong and will shoot the memory in your face if you're not careful!
  17. Mac mini Late 2018 Disassembly, Power supply connector: 步骤 17 中的图像 1,3 Mac mini Late 2018 Disassembly, Power supply connector: 步骤 17 中的图像 2,3 Mac mini Late 2018 Disassembly, Power supply connector: 步骤 17 中的图像 3,3
    • The power supply is secured in a similar way as with the previous models
    • A little clip has to be removed, and the connector can be rotated
  18. Mac mini Late 2018 Disassembly, Power supply screws: 步骤 18 中的图像 1,3 Mac mini Late 2018 Disassembly, Power supply screws: 步骤 18 中的图像 2,3 Mac mini Late 2018 Disassembly, Power supply screws: 步骤 18 中的图像 3,3
    • The power supply is held down with three TX6 screws
    • They look just like the fan screws, but they appear just a little bit thicker and with longer thread
  19. Mac mini Late 2018 Disassembly, End of the line: 步骤 19 中的图像 1,2 Mac mini Late 2018 Disassembly, End of the line: 步骤 19 中的图像 2,2
    • After taking out the power supply we are left with an empty shell
    • I really enjoyed taking this mini apart. My verdict is it's much easier than the 2014 model as cables are in a more logical place
结论
14等其他人完成本指南。
6指南评论
What happens to the machine if the SSD fails? Will the entire logic board need to be replaced? I have a feeling that the chances of SSD failing would be significantly higher than Ram… So shouldn’t apple make SSD removable as well?
Sam - 回复
Failing SSD means a failing motherboard. In my experience, apple ssd-s are very reliable. Upgradable memory allows you to use a device longer. If you configure it with 16GB today, you might want to max out the memory in the future, once prices go down.
Wouter de Vries -
What about the CPU, is it in a socket or soldered in?
Steve Seg - 回复
I didn’t have the courage to take the heatsink off. So we’ll have to wait for someone who does.
Wouter de Vries -
Mich würde interessieren, wie die CMOS Batterie getauscht wird, bzw. welcher Typ es ist.
Sven Arendsen - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 89
过去 30 天: 357
总计 11,583
