简介
使用本指南更换Mac mini(2024)的底盖。
你所需要的
要重新组装您的设备,请按照以下步骤的逆序操作:
维修没有按计划进行?尝试一些基本故障排除,或前往我们的 [Mac mini (2024) 维修论坛](https://www.ifixit.com/Answers/Device/Ma...) 寻求帮助。
3等其他人完成本指南。
由衷感谢以下译者:
75%
小左1120正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3指南评论
I ripped the crimps off of my power cable because I was pulling out instead of up. Is a new power button cable available for sale somewhere?
@alexdk I created a draft update to the guide with some text with an easier way to open this without potentially marring the aluminum with the Jimmy.
Can you take a look and maybe reword it and give it a test yourself using just a pair of normal spudgers, one in a vent slot to gently lift the edge and one to pry close to the "pins" next to the edge alignment plastic clips (which is a misnomer because they are only for alignment and don't clip anything, only the pins hold things together)?
You can always determine the correct orientation to pry near the pins because they are on the "ends" of the mac mini text, aka left and right as you are reading the words.
Hello!
Thank you for the suggestions! I tried out the double spudger technique, and it worked somewhat well. I had to really dig the tip of a spudger into the vent, which will have varying mileage for people with dull tips. It was also difficult to get a good enough angle so I could pry up on the edge of the Mac Mini without holding it down with another hand. With that said, I'll incorporate it as alternative procedure for people who want to avoid marring the aluminum (because you're 100% right it will probably happen). I'll make that clear.
