跳转到主内容
Mac Studio 2023 Speaker Replacement
你所需要的
  1. Mac Studio 2023 Speaker Replacement, Prepare your Mac Studio for disassembly: 步骤 1 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Prepare your Mac Studio for disassembly: 步骤 1 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Prepare your Mac Studio for disassembly: 步骤 1 中的图像 3,3
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. Mac Studio 2023 Speaker Replacement, Flip your Mac Studio over: 步骤 2 中的图像 1,1
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. Mac Studio 2023 Speaker Replacement, Heat the bottom cover screw pad: 步骤 3 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Heat the bottom cover screw pad: 步骤 3 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Heat the bottom cover screw pad: 步骤 3 中的图像 3,3
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. Mac Studio 2023 Speaker Replacement, Lift a section of bottom cover screw pad: 步骤 4 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Lift a section of bottom cover screw pad: 步骤 4 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Lift a section of bottom cover screw pad: 步骤 4 中的图像 3,3
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. Mac Studio 2023 Speaker Replacement, Separate the remaining adhesive: 步骤 5 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Separate the remaining adhesive: 步骤 5 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Separate the remaining adhesive: 步骤 5 中的图像 3,3
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. Mac Studio 2023 Speaker Replacement, Remove the bottom cover screw pad: 步骤 6 中的图像 1,1
    • Remove the bottom cover screw pad.
  7. Mac Studio 2023 Speaker Replacement, Reassembly information: 步骤 7 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Reassembly information: 步骤 7 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Reassembly information: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. Mac Studio 2023 Speaker Replacement, Remove the bottom cover screws: 步骤 8 中的图像 1,2 Mac Studio 2023 Speaker Replacement, Remove the bottom cover screws: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. Mac Studio 2023 Speaker Replacement, Remove the bottom cover: 步骤 9 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Remove the bottom cover: 步骤 9 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Remove the bottom cover: 步骤 9 中的图像 3,3
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. Mac Studio 2023 Speaker Replacement, Remove the power supply screws: 步骤 10 中的图像 1,2 Mac Studio 2023 Speaker Replacement, Remove the power supply screws: 步骤 10 中的图像 2,2
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. Mac Studio 2023 Speaker Replacement, Reposition your Mac Studio: 步骤 11 中的图像 1,1
    • Flip your Mac Studio around so the rear ports are facing you.
  12. Mac Studio 2023 Speaker Replacement, Disconnect the power cord port cable: 步骤 12 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Disconnect the power cord port cable: 步骤 12 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Disconnect the power cord port cable: 步骤 12 中的图像 3,3
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. Mac Studio 2023 Speaker Replacement, Tilt up the power supply: 步骤 13 中的图像 1,1
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. Mac Studio 2023 Speaker Replacement, Disconnect the power supply signal cable: 步骤 14 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Disconnect the power supply signal cable: 步骤 14 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Disconnect the power supply signal cable: 步骤 14 中的图像 3,3
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. Mac Studio 2023 Speaker Replacement, Remove the power supply: 步骤 15 中的图像 1,1
    • Remove the power supply.
  16. Mac Studio 2023 Speaker Replacement, Reposition your Mac Studio: 步骤 16 中的图像 1,1
    • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
  17. Mac Studio 2023 Speaker Replacement, Remove the internal frame screws: 步骤 17 中的图像 1,2 Mac Studio 2023 Speaker Replacement, Remove the internal frame screws: 步骤 17 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
    • Seven 5 mm‑long screws
    • One 4 mm‑long screw
  18. Mac Studio 2023 Speaker Replacement, Remove the internal frame: 步骤 18 中的图像 1,2 Mac Studio 2023 Speaker Replacement, Remove the internal frame: 步骤 18 中的图像 2,2
  19. Mac Studio 2023 Speaker Replacement, Remove the speaker screws: 步骤 19 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Remove the speaker screws: 步骤 19 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Remove the speaker screws: 步骤 19 中的图像 3,3
    • Use a T5 Torx screwdriver to remove the two 12 mm‑long screws securing the speaker.
  20. Mac Studio 2023 Speaker Replacement, Reposition the speaker: 步骤 20 中的图像 1,3 Mac Studio 2023 Speaker Replacement, Reposition the speaker: 步骤 20 中的图像 2,3 Mac Studio 2023 Speaker Replacement, Reposition the speaker: 步骤 20 中的图像 3,3
  21. Mac Studio 2023 Speaker Replacement, Disconnect the speaker: 步骤 21 中的图像 1,2 Mac Studio 2023 Speaker Replacement, Disconnect the speaker: 步骤 21 中的图像 2,2
    • Insert the point of a spudger under the speaker connector's plastic head and carefully lift it straight up and out of its socket.
    • Don't lift on the wires themselves, or you may damage them.
    • To reconnect the cable, position the connector head over its socket and press to with the flat end of a spudger—the connector should click into place.
  22. Mac Studio 2023 Speaker Replacement, Remove the speaker: 步骤 22 中的图像 1,1
    • Remove the speaker.
结论
Spencer Day
于09/14/22注册
150,037 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,640篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 41
总计 265
