跳转到主内容
MSI MS-1782 Motherboard Replacement
你所需要的
  1. MSI MS-1782 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Motherboard Replacement: 步骤 2 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 2 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Motherboard Replacement, Wi-Fi Card: 步骤 3 中的图像 1,3 MSI MS-1782 Motherboard Replacement, Wi-Fi Card: 步骤 3 中的图像 2,3 MSI MS-1782 Motherboard Replacement, Wi-Fi Card: 步骤 3 中的图像 3,3
    • Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
  4. MSI MS-1782 Motherboard Replacement: 步骤 4 中的图像 1,2 MSI MS-1782 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
  5. MSI MS-1782 Motherboard Replacement: 步骤 5 中的图像 1,2 MSI MS-1782 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the Wi-Fi card at its angle.
  6. MSI MS-1782 Motherboard Replacement, Cooling Assembly: 步骤 6 中的图像 1,3 MSI MS-1782 Motherboard Replacement, Cooling Assembly: 步骤 6 中的图像 2,3 MSI MS-1782 Motherboard Replacement, Cooling Assembly: 步骤 6 中的图像 3,3
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  7. MSI MS-1782 Motherboard Replacement: 步骤 7 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 7 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  8. MSI MS-1782 Motherboard Replacement: 步骤 8 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 8 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  9. MSI MS-1782 Motherboard Replacement: 步骤 9 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 9 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 9 中的图像 3,3
  10. MSI MS-1782 Motherboard Replacement: 步骤 10 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 10 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  11. MSI MS-1782 Motherboard Replacement: 步骤 11 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 11 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Gently lift the heat sink and then pull forwards towards you.
  12. MSI MS-1782 Motherboard Replacement, Battery: 步骤 12 中的图像 1,3 MSI MS-1782 Motherboard Replacement, Battery: 步骤 12 中的图像 2,3 MSI MS-1782 Motherboard Replacement, Battery: 步骤 12 中的图像 3,3
    • Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
    • Gently disconnect the cable connecting the M.2 caddy to the motherboard.
  13. MSI MS-1782 Motherboard Replacement: 步骤 13 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 13 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Remove the 3.6 mm screw holding the M.2 caddy in place using a JIS #1 screwdriver.
  14. MSI MS-1782 Motherboard Replacement: 步骤 14 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 14 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Gently disconnect the two blue ribbons.
  15. MSI MS-1782 Motherboard Replacement: 步骤 15 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 15 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 15 中的图像 3,3
    • Remove the 5.1 mm screw holding in the disk reader using a JIS #1 screwdriver.
    • Use an iFixit opening tool to push the back of the disk reader to push it out of the laptop's chassis.
  16. MSI MS-1782 Motherboard Replacement: 步骤 16 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 16 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 16 中的图像 3,3
    • Gently pull the disc reader out of the laptop.
    • Lift the plastic cover and disconnect the cable connected next to the speaker.
  17. MSI MS-1782 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove the five 5 mm screws holding the frame in place using a JIS #1 screwdriver.
  18. MSI MS-1782 Motherboard Replacement: 步骤 18 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 18 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 18 中的图像 3,3
    • Pry up on the battery frame with an opening tool and unclip from the main chassis, working your way around the laptop.
    • To remove the battery, pry up on it to unstick the adhesive.
    • A little Isopropyl alcohol under the battery can help unstick it from the frame.
  19. MSI MS-1782 Motherboard Replacement, Motherboard: 步骤 19 中的图像 1,3 MSI MS-1782 Motherboard Replacement, Motherboard: 步骤 19 中的图像 2,3 MSI MS-1782 Motherboard Replacement, Motherboard: 步骤 19 中的图像 3,3
    • Remove the five 5.6 mm screws holding the motherboard in place using a JIS #1 screwdriver.
    • Disconnect the display, keyboard, trackpad, and USB daughterboard ribbon connectors from the motherboard.
    • Before disconnecting the ribbon cables, lift the black tab before pulling the blue tabs on the cables.
    • Do not pull the cables out of the connector before lifting the black tab. Damage can occur to connector if not done so.
  20. MSI MS-1782 Motherboard Replacement: 步骤 20 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 20 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 20 中的图像 3,3
    • Remove the two screws holding the sound daughterboard in place.
    • Disconnect the cable attached to the board.
    • The daughterboard is still connected to the laptop so just place it to the right.
  21. MSI MS-1782 Motherboard Replacement: 步骤 21 中的图像 1,3 MSI MS-1782 Motherboard Replacement: 步骤 21 中的图像 2,3 MSI MS-1782 Motherboard Replacement: 步骤 21 中的图像 3,3
    • Lift the daughterboard and turn it to the back.
    • Lift the clear tape and pull the connector straight back to disconnect the daughterboard.
  22. MSI MS-1782 Motherboard Replacement: 步骤 22 中的图像 1,2 MSI MS-1782 Motherboard Replacement: 步骤 22 中的图像 2,2
    • Disconnect the USB daughterboard from the motherboard.
    • The orange ribbon cable is attached to the underside of the motherboard so it will stay attached when removing the motherboard.
  23. MSI MS-1782 Motherboard Replacement: 步骤 23 中的图像 1,2 MSI MS-1782 Motherboard Replacement: 步骤 23 中的图像 2,2
    • To remove the motherboard, lift it vertically out of the chassis.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 27
总计 231
