跳转到主内容
MSI GP62MVR 6RF Leopard Pro Keyboard Replacement
你所需要的
  1. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Bottom Cover: 步骤 1 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 2 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Hard Drive: 步骤 4 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Disconnect the hard drive and remove the hard drive from the device.
  5. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Battery: 步骤 5 中的图像 1,3 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Battery: 步骤 5 中的图像 2,3 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Battery: 步骤 5 中的图像 3,3
    • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
    • Remove the battery from the device.
  6. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Speakers: 步骤 6 中的图像 1,1
    • Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
  7. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 7 中的图像 1,1
    • On the front panel near the right speaker, there is a connection from the motherboard to the speakers.
    • Detach the white and black wiring from the clip.
  8. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 8 中的图像 1,1
    • Peel back the electrical tape holding the speaker wire in place.
    • Remove the speakers from the front panel, pulling upward.
    • Note that the screws holding the two speakers down were already removed during the bottom cover removal.
  9. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Heatsink: 步骤 9 中的图像 1,3 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Heatsink: 步骤 9 中的图像 2,3 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Heatsink: 步骤 9 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove twelve 4.5 mm screws fastening the heat sink to the motherboard.
    • Unclip the red, blue, and black intertwined wire gently from the left side of the motherboard.
    • Detach the black and red wire from the right side of the motherboard, as well as peel away the black tape connecting the large black wire to the motherboard.
  10. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 10 中的图像 1,1
    • Remove the heatsink from the device.
  11. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, USB Port: 步骤 11 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, USB Port: 步骤 11 中的图像 2,2
    • At the middle-top right of the motherboard, there is a ribbon wire connection to the USB port.
    • Detach the white and blue motherboard ribbon from the USB port.
  12. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 12 中的图像 1,1
    • Insert wisdom here.
  13. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Motherboard: 步骤 13 中的图像 1,1
    • At the top right of the motherboard, there is a wired connection to the charging port.
    • Disconnect the grey charger wire from its clip on the motherboard.
  14. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 14 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 14 中的图像 2,2
    • The final two connections are located one the underside of the motherboard.
    • Detach the small orange and bid grey ribbons from under the motherboard, by lifting the motherboard gently from the front.
  15. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 15 中的图像 1,1
    • Gently lift away the motherboard, directly upward.
  16. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Keyboard: 步骤 16 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement, Keyboard: 步骤 16 中的图像 2,2
    • Peel back the adhesive black lining attached to the keyboard.
  17. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 17 中的图像 1,1
    • Using a soldering iron, melt each red plastic attachment.
    • Note that although only one plastic connection is circled, all must be disconnected before removing the keyboard backing
    • Only the red plastic connections in the middle is required to be soldered; the outer connections can be undone with a prying tool.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  18. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 18 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 18 中的图像 2,2
    • Using a metal spudger, pry the keyboard metal backing away.
  19. MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 19 中的图像 1,2 MSI GP62MVR 6RF Leopard Pro Keyboard Replacement: 步骤 19 中的图像 2,2
    • Remove the keyboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 35
总计 1,398
