跳转到主内容
MSI GE72 6QF Apache Pro Keyboard Replacement
你所需要的
  1. MSI GE72 6QF Apache Pro Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 4 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 4 中的图像 2,2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 5 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 5 中的图像 2,2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 6 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 6 中的图像 2,2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Keyboard Replacement, Fan: 步骤 7 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement, Fan: 步骤 7 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement, Fan: 步骤 7 中的图像 3,3
    • If you are replacing only the keyboard, you can skip to step 18, and then skip the WiFi adapter removal step. The CPU fan, m.2 SSD, RAM and WiFi adapter (marked in green) will all come off with the main board, giving you access to the keyboard.
    • Use a Phillips #1 screwdriver to remove the ten 5.5mm screws.
    • Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
  8. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 8 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 8 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 8 中的图像 3,3
    • Unplug both of the fan power cords from the laptop using a spudger.
  9. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 9 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 9 中的图像 2,2
    • Continue to use the spudger to carefully separate the wires of the power cord from the laptop.
  10. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 10 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 10 中的图像 2,2
    • Fully remove the fans from the rest of the laptop.
  11. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 11 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 11 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 11 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the six 5mm screws.
    • Separate the fans from the silver fan covers.
  12. MSI GE72 6QF Apache Pro Keyboard Replacement, Hard Drive: 步骤 12 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement, Hard Drive: 步骤 12 中的图像 2,2
    • Remove the two 5.5mm screws with the Phillips #1 screwdriver.
  13. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 13 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 13 中的图像 2,2
    • Gently pull out the hard drive by wiggling it from right to left with your hands until it is removed.
  14. MSI GE72 6QF Apache Pro Keyboard Replacement, Optical Drive: 步骤 14 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement, Optical Drive: 步骤 14 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement, Optical Drive: 步骤 14 中的图像 3,3
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
  15. MSI GE72 6QF Apache Pro Keyboard Replacement, RAM: 步骤 15 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement, RAM: 步骤 15 中的图像 2,2
    • When you open the back cover, the RAM will be located as shown in the picture.
  16. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 16 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 16 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 16 中的图像 3,3
    • Press the hinges on the sides of the RAM chip as shown in the picture, in order to unlock it.
    • Carefully, slide it out at a 45 degree angle.
    • Don't press on the hinges too hard.
    • Be careful about the angle at which you're sliding out the chip.
  17. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 17 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 17 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 17 中的图像 3,3
    • Similarly, press on the hinges on the sides of the other RAM chip, in order to unlock it.
    • Some laptop models might not come with two RAM chips, so if that is your case, you can skip this step.
  18. MSI GE72 6QF Apache Pro Keyboard Replacement, SSD: 步骤 18 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement, SSD: 步骤 18 中的图像 2,2
    • Remove the single 5.5mm Phillips #1 screw attaching the SSD to the laptop.
  19. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 19 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 19 中的图像 2,2
    • Pull out the SSD by gently wiggling it from side to side until it comes out.
    • If the old SSD you removed contains the operating system, then the new SSD must also contain an operating system.
  20. MSI GE72 6QF Apache Pro Keyboard Replacement, Motherboard: 步骤 20 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement, Motherboard: 步骤 20 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement, Motherboard: 步骤 20 中的图像 3,3
    • Pull upward to lift the front speakers and sub-woofer out of place.
    • Carefully slide out the connectors for both of the speaker systems.
  21. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 21 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 21 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 21 中的图像 3,3
    • Use the Phillips #0 Screwdriver to remove the two 4mm screws that are holding the SATA connector in place.
  22. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 22 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 22 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 22 中的图像 3,3
    • Remove the WIFI card by disconnecting the two coax cables and removing the retaining screw.
    • Try to preserve the tape that covers the WIFI card so it can be reapplied.
  23. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 23 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 23 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 23 中的图像 3,3
    • Use the plastic opening tool to pry up the connector that holds the display cable so it can be disconnected.
    • The connector for the display cable flips upward, but be careful because it is fragile enough to break.
  24. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 24 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 24 中的图像 2,2
    • Remove the SD card reader by unscrewing the two 3 mm screws that hold it in place.
  25. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 25 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 25 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 25 中的图像 3,3
    • Remove the power and USB connectors that are connected to the left side of the motherboard by pulling them from the motherboard and SD card reader respectively.
    • The power connector pulls out without the chance of breaking, but the USB connector is another fragile flip-up style connector.
  26. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 26 中的图像 1,1
    • Disconnect the motherboard from the mouse key control board by pulling the connector out.
  27. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 27 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 27 中的图像 2,2
    • Disconnect the keyboard from the motherboard by carefully sliding the connectors out of the connections on the motherboard
  28. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 28 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 28 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 28 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the three 3.8 mm standoff screws that retain the motherboard and carefully remove it.
  29. MSI GE72 6QF Apache Pro Keyboard Replacement, Keyboard: 步骤 29 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement, Keyboard: 步骤 29 中的图像 2,2
    • Peel the silver tape off of the keyboard back plate.
  30. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 30 中的图像 1,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 30 中的图像 2,3 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 30 中的图像 3,3
    • Remove the thirteen 3 mm screws that fasten the keyboard in place.
  31. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 31 中的图像 1,2 MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 31 中的图像 2,2
    • Carefully lift and slide the keyboard out.
  32. MSI GE72 6QF Apache Pro Keyboard Replacement: 步骤 32 中的图像 1,1
    • Peel the yellow tape off of the back plate to free the keyboard so it can be separated from the plate.
    • Preserve this piece of tape so that it can be used when swapping in the new keyboard.
结论
9等其他人完成本指南。
3条评论
1) Remove a single CD/DVD tray screw when the bottom cover is still on.
2) Remove the CD/DVD tray.
3) Remove the rear trim.
4) Remove the bottom cover from the CD/DVD side to the USB side, as the bottom cover has a frame that goes around the USB ports.
Otherwise, TY for your effort.
frankjward69 - 回复
will this work for ge73 raider 8rf? i bought a keyboard to replace and have no instructions
M. Jaram - 回复
Someone please correct the time on this guide. There’s no way this is a 10 minute job!!
Plus the replacement keyboard (not bought yet) doesn’t seem to have the screw mount holes around the frame? Are there some steps missing to transplate the backing plate from the old keyboard to the new? Or should the new come with a backing plate with the required screw holes?
Cool_Breeze - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 18
过去 30 天: 59
总计 16,855
