跳转到主内容
MAGNAVOX MDV2300 Power Cord Replacement
你所需要的
  1. MAGNAVOX MDV2300 Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Make sure the device is unplugged from the wall.
  2. MAGNAVOX MDV2300 Power Cord Replacement: 步骤 2 中的图像 1,1
    • Unscrew the two screws that hold together the top panel.
  3. MAGNAVOX MDV2300 Power Cord Replacement: 步骤 3 中的图像 1,1
    • Remove the top panel.
  4. MAGNAVOX MDV2300 Power Cord Replacement: 步骤 4 中的图像 1,1
  5. MAGNAVOX MDV2300 Power Cord Replacement: 步骤 5 中的图像 1,2 MAGNAVOX MDV2300 Power Cord Replacement: 步骤 5 中的图像 2,2
    • Remove disc drive by unscrewing the 2 screws that hold the drive in place.
  6. MAGNAVOX MDV2300 Power Cord Replacement: 步骤 6 中的图像 1,1
    • Identify the power cord.
    • The cord must either be too short or torn to warrant replacement.
  7. MAGNAVOX MDV2300 Power Cord Replacement: 步骤 7 中的图像 1,1
    • Cut the old wire out from the chip.
    • Attach the new wire into the housing.
    • Line up new wire with the appropriate holes and solder to board.
    • The white wire will be your neutral and the black wire will be your negative. View link of how to solder in order to replace the power cord. http://www.instructables.com/id/How-to-s...
结论
After soldering, let cool and then reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Justin
于01/21/15注册
298 声望
创作了2篇指南
团队
Penn State, Team 1-41, Kaschak Winter 2015 Penn State, Team 1-41, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S1G41
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 532
